Observer enperez
Zc702 + 128Gb SD-CARD
Hello buddies!
I am wondering which is the maximum SD-CARD supported by this evaluation board??? The kit comes with a standard 8Gb SD-Card bit Can it supports a 128Gb SD-CArd?
Thanks in advance!
Community Manager
Community Manager
Re: Zc702 + 128Gb SD-CARD
There is no limitation on the size but on SDIO standard. Refer to AR#50991 for details.
Newbie erubio
I just try a 128GB  sdcard (samsung EVO Plus) and works fine. I do two partitions, the first one FAT32 (32 GB) to boot.
I formatted the second as ext4.
I am not using a Zc702 board, I use  the TE0720-03-1CR from Trenz but it should be the same.
