Zynq 7 Purpose of AXI FIFO Interfaces
As far as I understand the Zynq 7 Processing System supports up to 4 HP (High Performance) AXI MM slave interfaces.
But with every enabled HP interface I see that a corresponding FIFO CTRL interface also shows up in the block design's GUI.
What's the purpose of the FIFO CTRL interface ?
Re: Zynq 7 Purpose of AXI FIFO Interfaces
Hello @shaikon
I have attached a link to a forum question that will help answer your question. I also attached a link to the Zynq-7000 SoC Technical Reference Manual they reference in the forum.
Forum: https://forums.xilinx.com/t5/Processor-System-Design/What-is-S-AXI-HP0-FIFO-CTRL-interface/td-p/380317
UG585 TRM: https://www.xilinx.com/support/documentation/user_guides/ug585-Zynq-7000-TRM.pdf
I hope this helps!
I came across this thread before posting.
Unfortunately it didn't fully explain the necessity of the FIFO ports.
For example:
"The logic signals, SAXIHP{0-3}RDISSUECAP1_EN and SAXIHP{0-3}WRISSUECAP1_EN allow you to
change the issuing capability of the AFI block to the PS dynamically between two levels."
When should these FIFOs be written to or read from ?
@shaikon
Of course. I will work on finding you a sufficient answer to your question, so thank you for your patience.
@shaikon
From the TRM, these ports are described as follows...
"High Performance ports (AXI_HP) with
read/write FIFOs and two dedicated
memory ports on DDR controller and
a path to the OCM. "
A colleague has also explained that these parts allows for additional control/visibility of the FIFOs going into the PS. He also mentions that this is only ever used when advanced flow control is needed.
I hope this helps clarify the need for the ports!
