Participant sjg69
Zynq 7000 - Multiboot woes
I'm trying to generate a system where:
 - the user image is at 0x0 in QSPI address space
 - the golden image is at 0x1000000 in QSPI address space
 - if there is something wrong with the user image, the golden image will eventually boot.
From reading http://www.wiki.xilinx.com/x4.%20Time%20for%20Multiboot%20from%20QSPI it seems that this ought to work, because 0x1000000 is on a 32k boundary.
Both the user image and the golden image contain (in order) a FSBL image, the bitstream, and the corresponding elf image.
If I load either the golden master or the user image at 0x0, the device will boot just fine into that image.
If I load the user image at 0x0, the golden image at 0x1000000, then the user image loads and boots
If I then corrupt the user image by erasing the first 0x4000 bytes to 0xFF, and hit the reset button, the system never boots.
I can see that the correct QSPI addresses are being erased/written so it looks as though the golden image search isn't finding my golden master image for some reason. Anyone any clues ?
Community Manager
Community Manager
Re: Zynq 7000 - Multiboot woes
Please note that multiboot is not supported with pre-production devices (http://www.xilinx.com/support/answers/47588.html). Please ensure that you are targeting a production silicon.
Can you please read REBOOT_STATUS post boot failure to read the BOOTROM error code from it. This helps in understanding at what stage the boot fails.
