Zynq CAN bus problem
Hi there,
I used CAN controller in PS, and tested with the example code  "xcanps_polled_example" in loopback mode. It works.
Then I changed the loopback work mode to the normal mode. Meanwhile I connected the rx and tx pins together outside to make it a loopback outof zynq.
Then I ran the firmware to test the CAN bus. It appears that CAN didn't receive any from tx pin. Could you please help?
thx
Sam
Re: Zynq CAN bus problem
Thanks for your reply. My problem is different.
But I found the cause to the problem:
The constrant for CAN bus is that at least 2 nodes on the bus (the Tx node wait for the Rx node(s) to ACKnowledge the message, otherwise it is deemed invalid by all receiving nodes.  The zynq node won't ACK its own message.
I will try to test the CAN bus by a different approach.
