Observer f1xd
Zynq, FSBL handoff interrupted on PS-PL level shifters turned on
Hi!
I have a custom Zynq board. Test bitstream (works fine on PL), test app, no problems until i try to boot device from QSPI. FSBL works as it has to until handoff, then it calls ps7_post_config() which turns PS-PL level shifters. After that some interrupt occurs and FSBL IRQ handler initiates fallback.
There is no PL-PS activity expected with "hello world" in PS and simple LED blinker in PL. Both PL and PS seems to work fine. What could cause post-boot interrupt after turning on level shifters?
Re: Zynq, FSBL handoff interrupted on PS-PL level shifters turned on
The problem is that the ps is not instantiated in the pl so as soon as the pl to ps levelshifters turn on, the ps will receive core_xxx interrupts forever. There is a define statement that you can set in the fsbl to prwvent enabling of the levelshifters. I dont recall the define but it will be something like NO_PS_IN_BITFILE
Observer f1xd
NON_PS_INSTANTIATED_BITSTREAM
Thank you for the solution, could you please look on another question? http://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/Slow-QSPI-programming-rate/td-p/561180
