Voyager
Voyager
Zynq MPSoC PL reset
I have a MIG in the PL which requires an input reset. I need to configure a PLL prior to release the MIG reset.
Can I use a pl_resetn1 pin from the PS to control that reset? Or it's better to use an internal AXI GPIO.
--Sebastien
Voyager
Voyager
Re: Zynq MPSoC PL reset
In that case, I would use the internal AXI GPIO.
Ted Booth - Tech. Lead FPGA Design Engineer
www.designlinxhs.com
Voyager
Voyager
I would recommend using a "Processor System Reset" module.  Drive the "ext_reset_in" input from the PS and attach the "locked" signal from the PLL to the "dcm_locked" input.  That way you know the PLL is good to go before the MIG is released from reset.
Voyager
Voyager
My PLL is external and programmed using an I2C. So only the software knows whenever the frequency is ok.
--Sebastien
Voyager
Voyager
Voyager
Voyager
Ok. thanks Ted.
--Sebastien
