Visitor semiory
Zynq SPI Slave does not receive
Hi everyone,
I'm repeating the post because it was written as reply in the wrong category.
I have following issue with SPI Slave communication on Zybo board.
The SPI (SPI1, MISO = MIO11; MOSI = MIO10; CLK = MIO12; SC = MIO13) is configured with following code in SDK:
        int Status;
	XSpiPs_Config *SpiConfig;
	 * Initialize the SPI driver so that it's ready to use
	SpiConfig = XSpiPs_LookupConfig(SpiDeviceId);
	if (NULL == SpiConfig) {
		return XST_FAILURE;
	Status = XSpiPs_CfgInitialize(&SpiInstance, SpiConfig,
					SpiConfig->BaseAddress);
	if (Status != XST_SUCCESS) {
		return XST_FAILURE;
	 * The SPI device is a slave by default and the clock phase
	 * have to be set according to its master. In this example, CPOL is set
	 * to quiescent high and CPHA is set to 1.
	Status = XSpiPs_SetOptions((&SpiInstance), (XSPIPS_CR_CPHA_MASK) | (XSPIPS_CR_CPOL_MASK));
		return XST_FAILURE;
	 * Set the clock devider to minimal vlaue of 4
	 * according datasheet the maximal slave frequency shall be SPI Clock / (Clock Divider * 2) = 200 / 8 = 25 MHz
	 * which is the 25 Mbit
	Status = XSpiPs_SetClkPrescaler((&SpiInstance), XSPIPS_CLK_PRESCALE_4);
	 * Perform a self-test to check hardware build
	Status = XSpiPs_SelfTest(&SpiInstance);
		return XST_FAILURE;
	 * Connect the Spi device to the interrupt subsystem such that
	 * interrupts can occur. This function is application specific
	Status = SpiPsSetupIntrSystem(&IntcInstance, &SpiInstance, SPI_INTR_ID);
		return XST_FAILURE;
The sends the data correctly (it reacts on "chip select", and shifts all the bits in the right way with the comming "clock")
but does not receive anything....
If the XSpiPs_PolledTransfer() used, the controller stays in
             * Wait for the transfer to finish by polling Tx fifo status.
            CheckTransfer = (u32)0U;
            while (CheckTransfer == 0U){
            StatusReg = XSpiPs_ReadReg(
                            InstancePtr->Config.BaseAddress,
                                XSPIPS_SR_OFFSET);
                if ( (StatusReg & XSPIPS_IXR_MODF_MASK) != 0U) {
                     * Clear the mode fail bit
                    XSpiPs_WriteReg(
                        XSPIPS_SR_OFFSET,
                        XSPIPS_IXR_MODF_MASK);
                    return (s32)XST_SEND_ERROR;
                CheckTransfer = (StatusReg &
                            XSPIPS_IXR_TXOW_MASK);
forever because the StatusReg  is stays "0".
Could someone give an advice where the error can be? Did I forgot to configure something?
Thanks in Advance!
Re: Zynq SPI Slave does not receive
Hey @semiory,
Did you verify that there is something to receive, just to rule out hardware problems or detect issues with the MIO port config?
Herbert
Not sure if you are routing it through EMIO, if yes
You might not require all the signals under EMIO SPI_0 or SPI_1 when you route through EMIO.
You mostly require below mentioned signals
  1. emio_spi0_m_o -> MOSI
  2. emio_spi0_m_i  -> MISO
  3. emio_spi0_sclk_o -> CLK
  4. emio_spi0_ss_o_n -> SS
You need to expand the SPI0 or SPI1 port in pcw and make below mentioned four signals as external pins by right click and “make external” one by one .
Praveen
Visitor semiory
Hi @hpoetzl,
I did verify that the SPI Master (in my case a radio SOC CC2650) sends an array with 0x00 and 0xFF in the alternating manner to the Slave. But slave remains in the state of reception forerver...
I have already checked this issue using two Zybo-boards and the behavior is the same. Seems to be more general issue...
Thanks for your help.
Visitor semiory
Thank for your quick reply,
I'm not using the EMIO, but MIO instead. I have attached a printscreen with part of configuration.MIO_Config.pngThanks in advance!
Scholar ericv
Did you check if the IXR_TXOW bit is clear to 0 in the interrupt mask register?
If it is set (interrupt is disabled), the IXR-TXOW bit in the status register bit will always be 0.
Visitor semiory
Hi @ericv
I have added the following code to check the registers:
	u32 TX_Watemark = XSpiPs_GetTXWatermark(&SpiInstance);
	xil_printf("TX Watemark : ");
	xil_printf("%d \n\r",TX_Watemark);
    u32 RX_Watemark = XSpiPs_GetRXWatermark(&SpiInstance);
	xil_printf("RX Watemark : ");
	xil_printf("%d \n\r",RX_Watemark);
	u32 Check = (XSpiPs_ReadReg(SpiInstance.Config.BaseAddress, XSPIPS_SR_OFFSET) & XSPIPS_IXR_RXNEMPTY_MASK);
	xil_printf("IXR_RXNEMPTY (Rx FIFO Empty) : ");
	xil_printf("%d \n\r",(Check == XSPIPS_IXR_RXNEMPTY_MASK));
	Check = (XSpiPs_ReadReg(SpiInstance.Config.BaseAddress, XSPIPS_SR_OFFSET) & XSPIPS_IXR_TXOW_MASK);
	xil_printf("IXR_TXOW (Tx FIFO Overwater) : ");
	xil_printf("%d \n\r",(Check == XSPIPS_IXR_TXOW_MASK));
The status received after 200ms after transaction try (this time using the XSpiPs_Transfer((&SpiInstance),SendBufPtr, RecvBufPtr, ByteCount))
TX Watemark : 1
RX Watemark : 1
IXR_RXNEMPTY (Rx FIFO Empty) : 1
IXR_TXOW (Tx FIFO Overwater) : 0Best Regards
Scholar ericv
@semiory
could you dump the interrupt mask register?
That's the one I was referring to.
Scholar ericv
@semiory
An easy way to read that register is with this:
on SPI #0 : *((volatile unsigned int *)0xE0006010)
on SPI #1 : *((volatile unsigned int *)0xE0007010)
Visitor semiory
Hi @ericv
I have read the registers as You mentioned:
#define SPI_0_REG *((volatile unsigned int *)0xE0006010)
#define SPI_1_REG *((volatile unsigned int *)0xE0007010)
xil_printf("Actual Register SPI 0 is :");
u32 REG = SPI_0_REG;
xil_printf("%08x :", REG);
xil_printf("Actual Register SPI 1 is :");
REG = SPI_1_REG;
The result is:
Actual Register SPI 0 is : 0x00000000 -> is not activated.
Actual Register SPI 1 is : 0x00000027 -> 0b 00000000 00000000 00000000 00100111
Thanks in advance
Visitor semiory
Update
I haven't made the SPI self test before....
If I try to make it, the self test does not pass and returns an error because the "Interrupt Status" register has a wrong value after reset.
Reading of status register returns "0", but shall return XSPIPS_ISR_RESET_STATE==4 .
Has the problem solved yet? My SPI slave received all 0s.
