Observer palmercliff
Zynq Ultrascale+ MPSOC CAN Controller example project
Is there an example Vivado/SDK project using the CAN Controller on the Zynq Ultrascale+ MPSOC?  I know more about CAN than Zync and am hoping to get through the connection/configuration bits quickly.
Thanks!
Cliff
Re: Zynq Ultrascale+ MPSOC CAN Controller example project
Hi @palmercliff,
I hope you are asking about PS CAN which you need to enable in PS configuration and export hardware to SDK.
The example files will be listed for CAN in system.mss file which points to C:\Xilinx\SDK\2018.1\data\embeddedsw\XilinxProcessorIPLib\drivers\can_v3_2\examples .
Make use of the example to test at your end.
Praveen
Hi @palmercliff,
Praveen
Thank you Praveen, I think that will get me started.
Cliff
Observer julianop99
Hello
I need to run the same application, CANPS, but was looking for to run from standalone SDK application.
Is there a procedure how to use the available can_v3_2 driver?
Where shall I add the files, which files and if I need to run any tcl script?
In addition, where do I get the values for:
XPAR_OPB_CAN_0_DEVICE_ID,
XPAR_OPB_CAN_0_BASEADDR,
XPAR_OPB_CAN_0_CAN_NUM_ACF
I would appreciate any help.
Best regards.
