Zynq Ultrascale+ USB 3.0 Performance
We are evaluating the Zynq Ultrascale+ for a new product. I have a concern about the USB 3.0 ports.
Is their any bandwidth limitation if I use both USB 3.0 ports at super speed (5.0Gbps) with the Zynq UltraScale+?
We want to pump at least 250MB/s per USB 3.0 ports (bulk transferts) inside the PS DDR at the same time.
Best Regards,
Denis
Re: Zynq Ultrascale+ USB 3.0 Performance
HI @dalain00
Xilinx will not have beremetal driver support for USB host mode.
You can use Linux OS, to test USB hostmode and you will get USB3.0 host mode performance as you need.
Refer this link for Linux drivers:https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841873/Linux+Drivers
Configuration& Test procedure along with performance results:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842272/Zynq+Linux+USB+Device+Driver#ZynqLinuxUSBDeviceDriver-HostMode
Thanks & Regards
Aravind
Hi @dalain00,
Please check the test results of USB 3.0 on the ZCU102 board with standalone driver.
http://www.wiki.xilinx.com/ZynqMp+USB+Stadalone+Driver
Best Regards,
Srikanth
Thanks for the link.
The problem is we want to use the USB 3.0 ports in host mode. Do you have the same numbers for host mode? I know that this particular driver does not support host mode, but does Xilinx has a host driver for the USB 3.0 ports + bandwidth tests?
Best Regards,
Denis
HI @dalain00
Thanks & Regards
Aravind
Thanks for the link. I found all the answers I was looking for.
Best Regards,
Denis
