Newbie xorior
Zynq/Vivado: Audio Data Transfer between PL and PS / CDMA?
for my current project, I need to move audio data between PL and PS,
in a magnitude of maybe 16 stereo channels in&out, 24bit at 96kHz.
Using 32 bits/sample, this results in ~12MB/sec from PL to PS (Linux) and vice versa.
Being new to zynq, it seems to me that CDMA would be the way to go.
So my approach would be to buffer the samples from PL to PS in BRAM,
connecting one BRAM port to my logic and the other one to a AXI BRAM Controller.
Then I would put a CDMA Core to my design, it's master interface (inter)connected
to a PS HP Slave Port and the BRAM Controller.
The CDMA's slave interface would then be connected to the PS GP Master port.
Now, when the BRAM buffer is filled, I would trigger an interrupt from PL
and the PS would start a CDMA transfer from BRAM to the PS's DDR RAM.
After completion, the PS would start another transfer from DDR (containing the outgoing data)
to another BRAM buffer.
My question is: Does this sound sane? Or is there a better way to do it?
Thank you,
Hubert
Re: Zynq/Vivado: Audio Data Transfer between PL and PS / CDMA?
Hi Hubert,
That sounds reasonable to me. You should also look at just using an AXI DMA (instead of CDMA) which has a native streaming data interface which should be a bit easier to use. And the core can continue to send data as it receives it.
www.xilinx.com
"And the core can continue to send data as it receives it." . Would you please explain it to me ? Thanks.
I just mean that it streams data at a fast rate
www.xilinx.com
Teacher muzaffer
Another option is to use the OCM on the PS and talk to it using the ACP which is coherent. So for low rates of data like yours it's a much more convenient interface to create a mailbox and transfer small chunks of data (say 4/8 K) coherently
