Zynq and Microblaze simulation?
I'm working on zedboard and vivado 213.4 tool. I want to simulate my design composed of the Processing Zynq (dual ARM cortex-A9) and the Programmable Logic. The programmable Logic (PL) integrates four Microblazes wich communicates with the zynq.
My goal is to simulate my entire system (ARM & Microblaze).
Could you tell me please how can i simulate a design with microblaze and ARM processors.
Thanks in advance.
Teacher muzaffer
Re: Zynq and Microblaze simulation?
As of now, there is no hdl simulatable model for zynq's processor side. You can get a BFM model of zynq which models some of the peripheral and axi ports and generate transactions into the PL like the zynq would. I hear that Xilinx is working on a better zynq model.
Another option is to simulate the system using a system model ie use QEMU for zynq and link it with microblaze model. This mightt be quite a bit of work though.
Visitor pmnow
Hello, Are you able 2 simulate the Hetrogenous Model?. Earlier i tried a similar thing in XPS with Zedboard---although my ARM processor was working fine but i was unable 2 run any microblaze......I was confused if Zynq is workable in XPS as some documents suggested Vivado should be used instead...
This should work. How are you trying to do it?
Sikta
