Zynq simulation
I am working on Zynq simulation now, but I found it is not easy.
BFM can not used in Vivado 2017.
Is there any way I can run PS+PL simulation?
I want to verify DDR and AXI bus and evaluate the time delay within the whole process.
Any one can give me any hint?
Thanks a lot.
Re: Zynq simulation
Zynq BFM will be replaced by Xilinx Zynq Verification IP in CY2017.  For more information please contact your Local Xilinx Sales Contact.
Please check this videos and user guide for usage
https://www.xilinx.com/video/soc/how-to-use-the-zynq-7000-verification-ip-verify-debug-simulation.html
https://www.xilinx.com/video/hardware/how-to-use-axi-verification-ip-to-verify-debug-design-using-simulation.html
https://www.xilinx.com/products/design-tools/vivado/verification-ip.html#documentation
Thanks and Regards
Balkrishan
Re: Zynq simulation
Evaluating time delay in behavioral simulation is not likely the right approach- the model is not cycle-accurate. Consider running in hardware instead.
