Observer raymond.walter
ZynqMP ZCU102 XMPU DDR not working
I'm currently having the issue that I can't configure the XMPU on the ZCU102 properly.
I've set up the Registers manually according to the example in the TRM (UG1085 v1.5 page 364) and the Register Reference. After Setting up the regions to only having the APU as master I'm still able to access them via the RPU.
I've already stumbled upon this answer: https://www.xilinx.com/support/answers/69110.html but I suppose this doesn't apply when setting up the registers manually?
Kind Regards
Raymond Walter
Tags (4)
Re: ZynqMP ZCU102 XMPU DDR not working
Found the issue. The XMPU does not work in the Engineering Sample 1.
Source:http://www.origin.xilinx.com/support/answers/68021.html
"* Note: Isolation configuration is supported for all devices except ZU9-ES1"
