Visitor jangoris1
axi chip 2 chip
i'm having trouble with my design regarding to the chip 2 chip link between 2 fpga's
* first i do an axi read on the master side of the C2C link, everythings ok
* then i read on the slave side and everything freezes.
* but i can still read (with a different axi master) at the slave side
so i suppose it is the c2c link that causes the freeze, however the c2c link up signal is ok
so i have 2 questions:
is there a boot sequence that has to be respected ? Now my slave boots faster than the master
the slave C2C is version 5.0, the master is v4.2 -> can this cause any issues ?
Thanks for the input
regards
Jan
Visitor jangoris1
Re: axi chip 2 chip
updating vivado for the master project, and thus using the same core version for Chip2Chip seems to have solved the problem.
Jan
Community Manager
Community Manager
Re: axi chip 2 chip
Can you please share the .xci files? It is recommended to use the IP of same versions because there can be some changes done in the IP across versions (can be found in change log of IP).
Can you please insert ILA and see the status of RRESP in case of freeze?
Visitor jangoris1
Re: axi chip 2 chip
Jan
