bank0_ctrl0 (IOU_SLCR) Register Description
In UG1087 Zynq UltraScale+ MPSoC Register Reference:
Together with the bank0_ctrl1 [drive1] bit field, controls the output drive strength of MIO pins [0:25].
Drive table for [drive0], [drive1]:
00 = 2 mA
01 = 4 mA
10 = 8 mA
11 = 12 mA
So would drive0=1, drive1=0 be 8 mA?  This is confusing since the "drivex" bits are named backwards from the usual convention of 0 being the right most bit.  Also the description should read "[drive0] : [drive1]".
回复: bank0_ctrl0 (IOU_SLCR) Register Description
Hi @cmuhlbauer,
Yes, x means bank number.
Thank
Simon
Simon
Hi @cmuhlbauer,
Thank
Simon
Simon
