Observer micallef25
baremetal USB for Ultra 96 board
Hi, I was curious if the examples in the below path are supported for Ultra96 board
Xilinx\SDK\2018.3\data\embeddedsw\XilinxProcessorIPLib\drivers
I have tried building a few and have failed. Curious where to find some examples or how to get my hands on some src to be able to send raw data via usb3.0.
EDIT: build works after a few hacks and seems to not give error when running. I want to send data from one u96 to another u96 via usb one will always send one will always receive. The example seems to setup both EP handlers but how does one actually send the data?
I just want to send an array of bytes.
something like write_usb3(&buff[0],num_bytes_to_send)
but not sure on how to even do that with the example.
Also, If I can not send data from usb to usb using the usb drivers. Is it possible to do this with a usb to ethernet adaptor?
If I get such an adaptor at the end of the day I still need to use the usb3 drivers to send data correct?
Thank you!
