Observer liuzq71
can i disable the DLMB/ILMB?
In Vivado 2016.2,
my board design is as the picture below,
,Microblaze is connected to BRAM through DLMB/ILMB pins,so it will run the instructions located in BRAM, but i would like to Microblaze to run codes  on DDR,How can i do?thanks
Re: can i disable the DLMB/ILMB?
the microblaze will fetch the instruction from the memory address set in the base vector in the microblaze configuration in ipi upon exiting reset.
So, for your use case, you would need to change the base vector to your ddr. You would also need to hold the microblaze in reset until your ddr was calibrated.
You can enable the discrete signals in the microblaze, and set the reset-mode to 01,and connect the wake up to the Calib done from DDR.
I covered the concept in the wiki here, albeit I used the PS DDR on zynq. However, the idea is still the same.
Also, you will see a drop in performance from LMB to DDR
Observer liuzq71
thanks for your kindly reply.
In your designs here there is no LMB connected to Microblaze ,and my designs have,my problem is that if there is a LMB connected to Microblaze ,could Microblaze execute application located in DDR?how i must to do ?thanks
