Visitor richiechen
communication between ARM core and FPGA
Dear Friends
I am a newbie on FPGA programming. It would be definitely appreciated if you could give me some advices.
I would like to use ARM to trigger my I2C module. I2C module is implemented with VHDL in FPGA block.
It means that when ARM load a command into the registers of I2C module, I2C module will send the data into I2C devices and read back.
Here comes my questions:
1. How could ARM ask I2C(in FPGA) to do a designed operation? Is it achieved by ARM setting registers in FPGA?
2. If so, how to set the registers in FPGA by ARM? Could I use AXI? If AXI should be used, there are many AXI IPs, so which one should be used?
3. Upon the FPGA registers received the bytes from ARM, how could the I2C FPGA know that "new data has arrived, so I should start my FSM"?
Sorry my questions are too basic. It would be great if you could also give me some material to start with.
Thank you very much.
Best regards
Richie CHEN
Scholar austin
Re: communication between ARM core and FPGA
How about,
You tell us what FPGA device you are thinking of using?  Is it Zynq, which has both a built in ARM processor system, and also has I2C peripherals?  If so, you don't need to write any VHDL.  Only program in c.
Austin Lesea
Principal Engineer
Xilinx San Jose
Visitor richiechen
Dear Mr. Austin
Thanks for your reply. Yes we are using Zynq. However, we have decided to write a I2C in VHDL. It means that ARM needs to communicate with the I2C VHDL block.
Could you please inform me the way to communicate between VHDL COMPONENT and ARM?
Best regards
Richie CHEN
Scholar austin
Study the demo programs that come with the kit.
Austin Lesea
Principal Engineer
Xilinx San Jose
Visitor richiechen
Could you please explain more?
 I have not got the demo kit yet. But we would like to develop a bit first.
Is there a web address for the demo?
Scholar austin
http://www.xilinx.com/products/boards-and-kits/EK-Z7-ZC702-G.htm
Austin Lesea
Principal Engineer
Xilinx San Jose
Visitor richiechen
Hi Austin
I did not find any demo on the website
Could you please illustrate more?
Richie
Scholar austin
http://www.wiki.xilinx.com/Zynq+Base+TRD+14.1
Austin Lesea
Principal Engineer
Xilinx San Jose
Visitor sumit8915
Hi Richie,
   I am also working on same kind of application.
   If you have done with the implementation of  your mentioned application, please tell me the solution for the same.
Brief description of my application is:
I want to interface a small DAC circuit through pmod connectors of the zed board.
the data bus and the control signals of the DAC are wired with the pmod connectors
i am using planahead tool to create my project.
i want to write the a small state machine for controlling the DAC on my PL side of the ZYNQ.
for that i want to create some control registers and data register inside the PL side of the Zynq which i will be accessing from the ARM side.
Please help me how i can proceed for the Same.
Sumit Sharma
Visitor sumit8915
Any Other friend Who can answer the above post Please. ?
Teacher muzaffer
What you need to do is to create an axi4 lite slave peripheral for your device which implements the dac interface and exposes a register interface which then you connect to PS AXI GP port.
Visitor sumit8915
Hi Muzaffer,
Thanks for your quick reply .
i am using dac7728 IC from TI. and i am interfacing that with the Pmod connectors.
I have written a state machine in a seperate ise project for controlling the DAC7728 .
but how do i create the AXI4 lite slave peripheral for dac in the XPS.
Please send me some screen shots for step by step procedure or send me a link for the same.
Thanks friend
Sumit Sharma
Teacher muzaffer
Hardware | Create or Import Peripheral | Create templates | enter name | select axi4-lite in the next page. | finish creating the peripheral.
then insert your own code to the peripheral source files.
Visitor sumit8915
Thanks Friend, i will try to do this way.
Visitor sumit8915
Hi Muzaffer,
    I have create the peripheral in the EDK and imported in my design. iam able to open the ise project file which is created during project creation. after that i have added my code in the user_logic.v file .
But in my code i am assigning some signals to the FPGA I/O pins which i have to give to the pmod connectors of the zed board. During Bitstream generation im getting the error of not getting the pins as Constraint not found .
Could you please tell me how do i interface my user logic code again with the main .v file for assigning the signals to the FPGA I/O pins.
Thanks and Regards
Sumit Sharma
Teacher muzaffer
I am afraid I am not clear on what you issue is. Could you attach your project which shows the error to duplicate ?
Visitor sumit8915
 I am attching the two screenshots and my ISE project file which has been generated after ip creation.
 Also i have editted the user_logic. v file of the project for my own state machine.
 Please find the attachments.
Thanks and Regards
Sumit Sharma
Teacher muzaffer
You need to add the ports in the dac ucf to your hdl design too. Add them to the dac7728 module and propagate them down to the level where they are used/driven.
Visitor sumit8915
Thanks for the reply.
I will try this way... !!!
hello,
i readed your post, and i work on Zedboard ( Zynq-7000 based on 2 ARM ( Cortx-A9 ) processor
maybe it's similar to your question:
i have a question, can i make a simulaion on XPS or Vivado (  because, i haven't the board for this moment ?
thank you
My blog : www.xilinx-video.blogspot.com
Tags (4)
