create bin file with additional binary file
I use data2mem to combine the elf with fpga configuration.
I wanted to add some additional file in specific address in flash.
Can it be done using data2mem .
This is the current data2mem script I use:
data2mem -bm system_bd.bmm -bd xxx.elf -bt system.bit -o b xxx.bit
I need to merge myfile.bin too into address 0x400000 in flash.
Thank you,
Ran
Re: how to combine with additional binary file
Ok , I've solved the issue.
It relate to progmem swapping of bit order.
this post help me understand the issue:
http://forums.xilinx.com/t5/Embedded-Processor-System-Design/A-merged-MCS-file-not-work/td-p/146208
After "twice" swaping it works fine:
c:\Xilinx\14.7\ISE_DS\ISE\bin\nt64\promgen.exe -w -p bin -o images.bin -data_file up 0 images
c:\Xilinx\14.7\ISE_DS\ISE\bin\nt64\promgen.exe -o CZ5C2010A_uBlaze_POD.mcs -u 0 CZ5C2010A_uBlaze_POD.bit -data_file up 0x200000 images.bin -p mcs -w -bpi_dc parallel -data_width 16
Ran
Re: data2mem - how to combine with additional binary file
hi,
is this binary file will be programmed from a bpi/spi flash? if that is the case, you have to generate the updated bitstream with data2mem and use promgen to add the bin file and merge it into a single mcs
 promgen -spi -w -p mcs -u 0 download.bit -data_file up b40000 app1.bin -data_file up b40400 app2.bin
if this does not help, explain your use-case.
--hem
I don't understnad why it works if I program the file with "flash programming", but does not when it is part of the .mcs/bin file.
This is what I do:
@echo on
c:\Xilinx\14.7\ISE_DS\ISE\bin\nt64\data2mem -bm system_bd.bmm -bd CZ5C2010A_uBlaze_POD.elf -bt system.bit -o b CZ5C2010A_uBlaze_POD.bit
c:\Xilinx\14.7\ISE_DS\ISE\bin\nt64\promgen.exe -o CZ5C2010A_uBlaze_POD.mcs -u 0 CZ5C2010A_uBlaze_POD.bit -data_file up 0x200000 images -p mcs -w -bpi_dc parallel -data_width 16
c:\Xilinx\14.7\ISE_DS\ISE\bin\nt64\promgen.exe -o CZ5C2010A_uBlaze_POD.bin -u 0 CZ5C2010A_uBlaze_POD.bit -data_file up 0x200000 images -p bin -w -bpi_dc parallel -data_width 16
pause
Another thing I don't understand is why the command interpres the file offset as double the value given above:
D:\MicroBlaze\App\programming>c:\Xilinx\14.7\ISE_DS\ISE\bin\nt64\promgen.exe -o
Release 14.7 - Promgen P.20131013 (nt64)
Copyright (c) 1995-2013 Xilinx, Inc.  All rights reserved.
INFO:Bitstream:181 - The start address provided has been multiplied by a factor
   of 2 due to the use of the x16 data width
0x16a78c (1484684) bytes loaded up from 0x0
0xa8900 (690432) bytes loaded up from 0x400000
Using generated prom size of 8192K
Writing file "CZ5C2010A_uBlaze_POD.mcs".
Writing file "CZ5C2010A_uBlaze_POD.prm".
Writing file "CZ5C2010A_uBlaze_POD.cfi".
The file need to be set in assress 0x400000, so I put 0x200000. I wander why.
Any suggestion why this does not work with the combined file ?
Ran
Ran, the address differences by 2 are explained by the fact that the Flash is a 16-bit device and you are using bytes to ensure the location. This has been written about before in the Flash programming guides.
TomT...
Thanks for the that. It explaint the offset multiplication.
Is there any idea why the information is not written OK when using the MCS unified file with iMPACT, but works when using "flash programming" tool inside SDK ?
 Maybe it is related to Endiannes differences betweeen these 2 different writing options ?
Ran
Ran
