device tree for 2 DMA
Hi, I've instantiated a DMA in my Zynq project with Linux and it is working fine. Now my module needs a second DMA to read and write different data from the memory, these two DMAs will communicate with the same module inside the FPGA using AXIS (but right now is all loop back).
When I edit my device tree just replicating the first one and changing the address I get a panic message from Kernel :
Unhandled fault: imprecise external abort (0x406) at 0x00000000
Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000007
\0x14CPU1: stopping
\0x14CPU: 1 PID: 0 Comm: swapper/1 Not tainted 3.15.0-xilinx #1
@h\0xc5\0x1a\0xc1013f00>] (unwind_backtrace) from [<c0010570>] (show_stack+0x10/0x14)
P[<c0010570>] (show_stack) from [<c04ec2a0>] (dump_stack+0x88/0xd8)
([<c04ec2a0>] (dump_stack) from [<c0012810>] (ipi_cpu_stop+0x3c/0x6c)
\0x14[<c0012810>] (ipi_cpu_stop) from [<c0012eac>] (handle_IPI+0x60/0x80)
\0x14[<c0012eac>] (handle_IPI) from [<c00084e0>] (gic_handle_irq+0x54/0x5c)
([<c00084e0>] (gic_handle_irq) from [<c0010f80>] (__irq_svc+0x40/0x70)
\0x14Exception stack(0xe6c8bf68 to 0xe6c8bfb0)
\0x14bf60: e6c8bfb0 00000004 fcfe7cca 00000000 e71a10e0 00000000
\0x14bf80: fcba6ca3 00000000 c0727e98 413fc090 c0727e98 00000000 00000000 e6c8bfb0
\0x14bfa0: c005d248 c03a2058 60000113 ffffffff
([<c0010f80>] (__irq_svc) from [<c03a2058>] (cpuidle_enter_state+0x50/0xe8)
([<c03a2058>] (cpuidle_enter_state) from [<c004d50c>] (cpu_startup_entry+0x14c/0x1c0)
\0x14[<c004d50c>] (cpu_startup_entry) from [<00008584>] (0x8584)
\0x14---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000007
my original and working device tree address is
axi_dma_0: axi_dma_0@40400000 {
            axistream-connected = <&axi_dma_0>;
                    axistream-control-connected = <&axi_dma_0>;
            #dma-cells = <1>;
            clock-names = "s_axi_lite_aclk", "m_axi_sg_aclk", "m_axi_mm2s_aclk", "m_axi_s2mm_aclk";
            clocks = <&clkc 15>, <&clkc 15>, <&clkc 15>, <&clkc 15>;
            compatible = "xlnx,axi-dma","xlnx,axi-dma-1.00.a","xlnx,axi-dma-6.03.a";
            interrupt-names = "mm2s_introut", "s2mm_introut";
            interrupt-parent = <&intc>;
            interrupts = <0 33 4 0 34 4>;
            xlnx,enable-multi-channel = <0x0>;
            xlnx,family = "zynq";
                xlnx,generic = <0x0>;
            xlnx,include-mm2s = <0x1>;
            xlnx,include-mm2s-dre = <0x1>;
            xlnx,include-mm2s-sf = <0x1>;
            xlnx,include-s2mm = <0x1>;
            xlnx,include-s2mm-dre = <0x1>;
            xlnx,include-s2mm-sf = <0x1>;
            xlnx,instance = "axi_dma_0";
            xlnx,mm2s-burst-size = <16>;
            xlnx,s2mm-burst-size = <16>;
            reg = <0x40400000 0x10000>;
            //xlnx,include-sg;
            xlnx,addrwidth = <64>;
            //xlnx,sg-length-width = <64>;
            dma-channel@40400000 {
                compatible = "xlnx,axi-dma-mm2s-channel";
                dma-channels = <0x1>;
                interrupts = <0 33 4>;
                xlnx,datawidth = <64>;
                xlnx,device-id = <0x0>;
            dma-channel@40400030 {
                compatible = "xlnx,axi-dma-s2mm-channel";
                interrupts = <0 34 4>;
                xlnx,device-id = <0x1>;
axidmatest_1: axidmatest@1 {
                     compatible ="xlnx,axi-dma-test-1.00.a";
                     dmas = <&axi_dma_0 0
                             &axi_dma_0 1>;
                     dma-names = "axidma0", "axidma1";
which I just duplicated for :
axi_dma_1: axi_dma_1@40410000 {
            axistream-connected = <&axi_dma_1>;
                    axistream-control-connected = <&axi_dma_1>;
            #dma-cells = <1>;
            interrupts = <0 35 4 0 36 4>;
            reg = <0x40410000 0x10000>;
            //xlnx,include-sg;
            dma-channel@40410000 {
                interrupts = <0 35 4>;
                xlnx,device-id = <0x2>;
            dma-channel@40410030 {
                interrupts = <0 36 4>;
                xlnx,device-id = <0x3>;
axidmatest_2: axidmatest@2 {
                     dmas = <&axi_dma_1 0
                             &axi_dma_1 1>;
                     dma-names = "axidma2", "axidma3";
A FURTHER question is :
is it better if the use a new second HP at Zynq , HP1 and  for my second DMA ?
Re: device tree for 2 DMA
I solved it with two GP and HP , then it created all address right and worked with Linux and my driver that uses DMA registers.
No problems at dmesg and all dmas detected :
cat /proc/interrupts
63:          0          0       GIC  63  gpio1
 64:          0          0       GIC  64  gpio2
 65:          0          0       GIC  65  xilinx-dma-controller
 66:          0          0       GIC  66  xilinx-dma-controller
 67:          0          0       GIC  67  xilinx-dma-controller
 68:          0          0       GIC  68  xilinx-dma-controller
cat /proc/iomem
00000000-2fffffff : System RAM
00008000-006b9587 : Kernel code
006ee000-00763323 : Kernel data
40400000-4040ffff : /amba/axi_dma_0@40400000
80400000-8040ffff : /amba/axi_dma_1@80400000
cat /proc/iomem
Hi, I am testing two dmas and I have met a question is that how to modify the device and the dma driver source code . According to your way to modifing the device tree I wonder how to modify the driver source code ? My source code is from github https://github.com/bperez77/xilinx_axidma/tree/master/driver , can you give me some suggestions ? Thank you very much.
