Observer mohamd17
how to set values in the same register in the PL side
Hello
I have flags that I set from my PS soc. Know to read them from PL side I have an implementation error when I use the same register !
    test1 <= slv_reg3(31);
    test2 <= slv_reg3(30);
    PSenable <= slv_reg3(29);
Thank you
Re: how to set values in the same register in the PL side
@mohamd17 wrote:
yes but this is done on purpose.
How to write several times on the same register and avoid this error ?
	en_ram_wr <= slv_reg3(31);
	en_ram_rd <= slv_reg3(30);
Use the OR gate. For example, in Verilog:
@always @(posedge clock)
  if (writeEnable1) slv_reg <= data1;
  else if (writeEnable2) slv_reg <= data2;
Make sure that all signals are synchronous to clock.
Joe Samson
Scholar dpaul24
It is showing a multi driver problem, it is having 2 drivers.
slv_reg3(31) bit is being driven from en_ram_wr_reg/Q and slv_reg3_reg[31]/Q. Check your connections to slv_reg3(31) and fix it.
Regards.
FPGA enthusiast!
All PMs will be ignored
Observer mohamd17
Joe Samson
Scholar dpaul24
The above OR gate example is perhaps the simplest.
I don't know your design so I am speculating. Say for e.g. if 3 signals have to change a bit (which is a register), then you should have a MUX whose select lines would govern which signal will change the bit value. You can't connect all the 3 signals to this bit. It would generate a multi-driven condition as you have now.
Ans yes, for registers this change should happen at the rising edge of the clock.
FPGA enthusiast!
Observer mohamd17
thank you, I translated that into VHDL and it works.
It was necessary to make a condition on each bit of the register, this allows to write and read on the same register several times.
