input digital signal on ZC706
Dear all,
I am working with the ZC706 eval board I need to import an external digital signal to a custom core. In this case,  I will  select this signal as peripheral, right? As I am using the ZC706, this evaluation board has GTX TX&RX external SMAs for differential user clock input. My question is if I could use this board input and how I could set an external signal on it.
Re: input digital signal on ZC706
refer to UG898
