/lib/ld-linux-armhf.so.3 vs /lib/ld-linux.so.3
Hello.  I just recently upgraded Vivado and PetaLinux to 2017.1 so they could be on the same version to resolve the missing mtd device problem.  A problem I am running into is that PetaLinux 2017.1 uses the library name /lib/ld-linux-armhf.so.3 according to the new standardization.  The 2017.1 sdk apparently is using the old library pathname of  /lib/ld-linux.so.3 as its little elf self is unable to start start unless a symlink is in place
ln -s /lib/ld-linux-armhf.so.3 /lib/ld-linux.so.3
I found a stackoverflow article telling how to add this link creation to the PetaLinux yocto library definition but it didn't work.  I also tried adding it in the do_install function
         mkdir ${D}/lib
         ln -s /lib/ld-linux-armhf.so.3 ${D}/lib/ld-linux.so.3
but although that gets the lib in the generated rpm, it doesn't transfer all the way into the file system image at
       ./images/linux/rootfs.cpio
So at this point I realize Yocto is over my head and that the SDK 2017.1 should be compatible with the PetaLinux 2017.1 anyway.  I am assuming there is a compile flag I should be able to give gcc which would make it use the correct ld-linux.so.3 library file.  I suppose I could also dynamically generate the library link each time the board boots, but it seems like that shouldn't be needed.  Thanks for looking into this.
Re: /lib/ld-linux-armhf.so.3 vs /lib/ld-linux.so.3
Interesting.  So I started a new C++ project in the SDK to try to iron something else out and the executable it generates links to the new library location /lib/ld-linux-armhf.so.3.  I figured this out by trying to run it on the older Linux from PetaLinux 2014 and it produced the same error until I produced the same link in reverse.  So apparently there are settings somewhere that do not get upgraded when you upgrade the software.  I suppose if I have to I can recreate the project and re-add the source files again.
