Visitor kennykoller
libc.a That Does Not Use the VFP/NEON Registers
We are attempting to use FreeRTOS along with hardware floating point (VFP) support and C++. I am building with -mfloat-abi=softfp and I have instructed FreeRTOS to save the D0-D31 registers during context switches.
A problem is that memcpy/memset/memcmp make use of the NEON/VFP registers for efficiency. This is mentioned on the FreeRTOS site.
I took the nonoptimized C implementations of these three functions from the FreeRTOS 8.2.2 distribution and they are selected by the linker rather than those found in libc.a. However when I look through the instructions of the .elf file I still see some vpush from several other library routines.
It's not practical to comb through the final binary and re-write each routine. Where may I find a libc.a that does not make use of these registers?
Visitor kennykoller
Re: libc.a That Does Not Use the VFP/NEON Registers
Actually, I suppose this will be fine so long as none of those routines are called from an interrupt. memcpy was an issue because some of the FreeRTOS ISR routines called it. Still it'd be nice to have an optimized non VFP library for memcpy etc.
