lwip on Zynq Ultrascale ZCU102 - Crash due to invalid pbuf pointer on xemacif_input
I am developing a simple sever, based on the sample echo server, running on one of the RPUs. I am now testing the stability of this server by sending random data buffers of random size (0-128 bytes), in high speed.
In this scenario, it doesn't take long for the program to crash. I found that it crashes when it tries to free an invalid pbuf pointer when calling to xemacif_input.
Also, increasing the following parameters (or maybe only one of them) seemingly solves the problem, or at least, it doesn't occur immediately:
  1. pbuf_pool_size
    from 256 to 8192
  2. tcp_send_buf
    from 8192 to 65535
  3.  memp_n_buf
    from 16 to 1024
  4. memp_n_tcp_seg
    from 256 to 1024
This means that the problem is probably a matter of insufficient resources, but I would like to prevent the program from crashing without increasing the available memory, and for this matter I don't mind missing some incoming data or not being able momentarily to send data, in case I am out of memory.
Can someone help me solve this issue?
Amon.
Tags (3)
Re: lwip on Zynq Ultrascale ZCU102 - Crash due to invalid pbuf pointer on xemacif_input
There is debug parameters that can be enabled in the LwIP settings. Can  you enable these and these should indicate exactly what the issue is.
Yes, I'm aware of this option. The problem is that there far too many printouts, and along with a missing "\r" (line feed) in the lwip debug print, it makes them impossible to be understood.
Another thing, when I do set these parameters, the server stops listening at some point. That is, it continues its execution, but the accept callback isn't being invoked.
