microblaze, central DMA, SDRAM and custom IP connection
Hi All
I have a specific purpose of using plb bus. I want to built a model where where microblze will write few data into a specific source address range of SDRM memory using XPS central DMA. A custom IP will read those data, and process some arithmetic operation and again that will be sent to another destination address of SDRM. That thing I already did with AXI bus and DMA engine but for XPS central DMA I am little bit confused. I am wondering how DMA slave and master bus, SDRM slot and slave bus of my costume IP will be connected. It is to be noted that few more IP are connected with microblaze with a PLB bus
Teacher muzaffer
Re: microblaze, central DMA, SDRAM and custom IP connection
cdma probably needs to be controlled by MB so slave is connected to MB. Master is connected to a dram controller port. Your custom IP's memory master should be connected to another dram controller port and custom IP's slave port should be connected to the MB for control.
check this old presentation
http://ead.ipleiria.pt/ucs201415/pluginfile.php/240248/mod_resource/content/1/AulaT9_adding_ip.pdf
Thanks and Regards
Balkrishan
Is there any example design available?
Community Manager
Community Manager
You can refer to http://www.fpgadeveloper.com/2014/03/using-the-axi-dma-engine.html
This design targets AXI DMA but you can replace AXI DMA with AXI CDMA in your design. The remaining interfaces should be the same.
