microblaze starts very slowly using MIG
Hi, I designed a microblaze using cache and MIG (DDR3) according to xilinx example. My microblaze uses "maximum frequency" profile, and runs at 200MHz. DDR3 runs at 400MHz with 2:1 divider, and has 256MB.
I use system debugger to download bitstream and elf (standalone application) to run it. But I found the application needs a very long time before running to main(). I stepped the assembly code, and found that startup code cosumes much time (about more than one minute) on initializing .BSS section (about 70MB) to zeros.
This is unacceptable. Is this normal?
