processing system using Genesys 2
Using vivado 2018.1 with genesys 2 FPGA board, how can i  add the processing system IP core to my design?
I'm trying to add it using IP catalogue but unfortunately i can not found it.
Thank you in advance
Re: processing system using Genesys 2
Only the Zynq-7 SoCs and Zynq Ultrascale+ MPSoCs have hardened processor cores. The Genesys 2 is part of the Kintex-7 family which do not have harnened processor cores. Luckily, you can use the MicroBlaze which is a soft processor core that implements directly into the FPGA fabric.
Have you tried this? Let me know!
More on soft vs hard processors: https://electronics.stackexchange.com/questions/55377/soft-core-processors-vs-hard-core-processors
Read more about the MicroBlaze: https://www.xilinx.com/products/design-tools/microblaze.html#overview
