Visitor mohamad_7
read/write slave register in PPC405
I have 2 slave registers. I write into register (slv_reg0). This register is read by my IP ( it is just 2 DFF connected in series)  output from MY IP is stored in the other register (slv_reg1) ... my problem is i cant write in the slv_reg0 so my IP can read any input hence my slv_reg1 doesnt receive any input therefore it remains 0
my logic code is ....
component top is port(d, clk:in std_logic; q:out std_logic); end component; begin --USER logic implementation added here dff1 : top port map (q => slv_reg0(0), clk => clk_top, q => slv_reg1(0)); slv_reg_write_select <= Bus2IP_WrCE(0 to 1); slv_reg_read_select <= Bus2IP_RdCE(0 to 1); slv_write_ack <= Bus2IP_WrCE(0) or Bus2IP_WrCE(1); slv_read_ack <= Bus2IP_RdCE(0) or Bus2IP_RdCE(1); implement slave model register(s) SLAVE_REG_WRITE_PROC : process( Bus2IP_Clk ) is begin if Bus2IP_Clk'event and Bus2IP_Clk = '1' then if Bus2IP_Reset = '1' then slv_reg0 <= (others => '0'); -- slv_reg1 <= (others => '0'); else case slv_reg_write_select is when "10" => for byte_index in 0 to (C_DWIDTH/8)-1 loop if ( Bus2IP_BE(byte_index) = '1' ) then slv_reg0(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7); end if; end loop; -- when "01" => -- for byte_index in 0 to (C_DWIDTH/8)-1 loop -- if ( Bus2IP_BE(byte_index) = '1' ) then -- slv_reg1(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7); -- end if; -- end loop; when others => null; end case; end if; end if; end process SLAVE_REG_WRITE_PROC; -- implement slave model register read mux SLAVE_REG_READ_PROC : process( slv_reg_read_select, slv_reg0, slv_reg1 ) is begin case slv_reg_read_select is when "10" => slv_ip2bus_data <= slv_reg0; when "01" => slv_ip2bus_data <= slv_reg1; when others => slv_ip2bus_data <= (others => '0'); end case; end process SLAVE_REG_READ_PROC; **************************************** my C code is // Located in: ppc405_0/include/xparameters.h #include "xparameters.h" #include "dff.h" //==================================================== int main (void) { int j; for(j=0;j<10;j++) { DFF_mWriteSlaveReg0(XPAR_DFF_0_BASEADDR, 1); long d_s = DFF_mReadSlaveReg0(XPAR_DFF_0_BASEADDR); long q = DFF_mReadSlaveReg1(XPAR_DFF_0_BASEADDR); printf ("----------------- \n"); printf ("q = %x \n",q); printf ("d = %x \n",d_s); sleep(1); } return 0; }
Visitor jralph
Re: read/write slave register in PPC405
How does is simulate for you? Or if you're jumping straight onto the chip without verification, if you change the reset value of slv_reg0/1 are you able to read the registers as you would expect? You should be able to use the C IDE's memory monitor and see the reset values and also read/modify registers with the monitor or C.
Are you connecting your IP up using XPS?  Not sure what automagic XPS is doing these days -- do you need the bus ports in your component def?  I would be sure to register all outputs.
To simplify things you could assume each register access is a 32bit aligned word.
