Observer mohamd17
receive 256 bits data from PS via axi lite slave
Hey evryone !
I'm really stuck for a few days!
I am sending 256 bits looped from my PS. But I think that I get juste the last 4 bytes of 8*4 that i send !
What I want from you is a few vhdl code line that allow me to receive all of my data (8 * 32 bits).
result of send_receive data
You will find enclosed a photo of the result that I get
Waiting for your reply. thank you
I send my data on register 1 and I have to store it in ram
Here a pseudo code c that allow me to send 8*32 bits:
for(int i = 0; i < 8; i++){
    Data_struct -> in = message[i] ;
the vhdl code of AXI lite :
library ieee;
    use ieee.std_logic_1164.all;
    --use ieee.numeric_std.all;
    use ieee.std_logic_arith.all;
    use ieee.std_logic_unsigned.all;
    entity axi_lite1_v1_0_S00_AXI is
        generic (
            -- Users to add parameters here
            -- User parameters ends
            -- Do not modify the parameters beyond this line
            -- Width of S_AXI data bus
            C_S_AXI_DATA_WIDTH    : integer    := 32;
            -- Width of S_AXI address bus
            C_S_AXI_ADDR_WIDTH    : integer    := 4
        port (
            -- Users to add ports here
            --input_data : in std_logic_vector(C_S_AXI_DATA_WIDTH - 1 downto 0);
            -- User ports ends
            -- Do not modify the ports beyond this line
            -- Global Clock Signal
            S_AXI_ACLK    : in std_logic;
            -- Global Reset Signal. This Signal is Active LOW
            S_AXI_ARESETN    : in std_logic;
            -- Write address (issued by master, acceped by Slave)
            S_AXI_AWADDR    : in std_logic_vector(C_S_AXI_ADDR_WIDTH-1 downto 0);
            -- Write channel Protection type. This signal indicates the
                -- privilege and security level of the transaction, and whether
                -- the transaction is a data access or an instruction access.
            S_AXI_AWPROT    : in std_logic_vector(2 downto 0);
            -- Write address valid. This signal indicates that the master signaling
                -- valid write address and control information.
            S_AXI_AWVALID    : in std_logic;
            -- Write address ready. This signal indicates that the slave is ready
                -- to accept an address and associated control signals.
            S_AXI_AWREADY    : out std_logic;
            -- Write data (issued by master, acceped by Slave)
            S_AXI_WDATA    : in std_logic_vector(C_S_AXI_DATA_WIDTH-1 downto 0);
            -- Write strobes. This signal indicates which byte lanes hold
                -- valid data. There is one write strobe bit for each eight
                -- bits of the write data bus.
            S_AXI_WSTRB    : in std_logic_vector((C_S_AXI_DATA_WIDTH/8)-1 downto 0);
            -- Write valid. This signal indicates that valid write
                -- data and strobes are available.
            S_AXI_WVALID    : in std_logic;
            -- Write ready. This signal indicates that the slave
                -- can accept the write data.
            S_AXI_WREADY    : out std_logic;
            -- Write response. This signal indicates the status
                -- of the write transaction.
            S_AXI_BRESP    : out std_logic_vector(1 downto 0);
            -- Write response valid. This signal indicates that the channel
                -- is signaling a valid write response.
            S_AXI_BVALID    : out std_logic;
            -- Response ready. This signal indicates that the master
                -- can accept a write response.
            S_AXI_BREADY    : in std_logic;
            -- Read address (issued by master, acceped by Slave)
            S_AXI_ARADDR    : in std_logic_vector(C_S_AXI_ADDR_WIDTH-1 downto 0);
            -- Protection type. This signal indicates the privilege
                -- and security level of the transaction, and whether the
                -- transaction is a data access or an instruction access.
            S_AXI_ARPROT    : in std_logic_vector(2 downto 0);
            -- Read address valid. This signal indicates that the channel
                -- is signaling valid read address and control information.
            S_AXI_ARVALID    : in std_logic;
            -- Read address ready. This signal indicates that the slave is
                -- ready to accept an address and associated control signals.
            S_AXI_ARREADY    : out std_logic;
            -- Read data (issued by slave)
            S_AXI_RDATA    : out std_logic_vector(C_S_AXI_DATA_WIDTH-1 downto 0);
            -- Read response. This signal indicates the status of the
                -- read transfer.
            S_AXI_RRESP    : out std_logic_vector(1 downto 0);
            -- Read valid. This signal indicates that the channel is
                -- signaling the required read data.
            S_AXI_RVALID    : out std_logic;
            -- Read ready. This signal indicates that the master can
                -- accept the read data and response information.
            S_AXI_RREADY    : in std_logic
    end axi_lite1_v1_0_S00_AXI;
    architecture arch_imp of axi_lite1_v1_0_S00_AXI is
        -- AXI4LITE signals
        signal axi_awaddr    : std_logic_vector(C_S_AXI_ADDR_WIDTH-1 downto 0);
        signal axi_awready    : std_logic;
        signal axi_wready    : std_logic;
        signal axi_bresp    : std_logic_vector(1 downto 0);
        signal axi_bvalid    : std_logic;
        signal axi_araddr    : std_logic_vector(C_S_AXI_ADDR_WIDTH-1 downto 0);
        signal axi_arready    : std_logic;
        signal axi_rdata    : std_logic_vector(C_S_AXI_DATA_WIDTH-1 downto 0);
        signal axi_rresp    : std_logic_vector(1 downto 0);
        signal axi_rvalid    : std_logic;
        -- Example-specific design signals
        -- local parameter for addressing 32 bit / 64 bit C_S_AXI_DATA_WIDTH
        -- ADDR_LSB is used for addressing 32/64 bit registers/memories
        -- ADDR_LSB = 2 for 32 bits (n downto 2)
        -- ADDR_LSB = 3 for 64 bits (n downto 3)
        constant ADDR_LSB  : integer := (C_S_AXI_DATA_WIDTH/32)+ 1;
        constant OPT_MEM_ADDR_BITS : integer := 1;
        ---- Signals for user logic register space example
        ---- Number of Slave Registers 4
        signal slv_reg0    :std_logic_vector(C_S_AXI_DATA_WIDTH-1 downto 0);
        signal slv_reg1    :std_logic_vector(C_S_AXI_DATA_WIDTH-1 downto 0);
        signal slv_reg2    :std_logic_vector(C_S_AXI_DATA_WIDTH-1 downto 0);
        signal slv_reg3    :std_logic_vector(C_S_AXI_DATA_WIDTH-1 downto 0);
        signal slv_reg_rden  : std_logic;
        signal slv_reg_wren : std_logic;
        signal reg_data_out : std_logic_vector(C_S_AXI_DATA_WIDTH-1 downto 0);
        signal byte_index : integer;
        constant ADDRESS_SIZE : integer := 4;
        signal address_in : std_logic_vector(ADDRESS_SIZE - 1 downto 0);
        signal ready_pl : std_logic := '0';
        signal reset : std_logic := '1';
        signal en_ram : std_logic;
        signal getPSData    : std_logic_vector(C_S_AXI_DATA_WIDTH-1 downto 0);
        signal DataDone    : std_logic_vector(C_S_AXI_DATA_WIDTH-1 downto 0);
        signal PSenable : std_logic;
        signal PLdone : std_logic := '0';
        signal test : std_logic := '1';
        signal Count : integer :=0;
        constant width_ram : integer :=32;
        type ram_type is array (0 TO 2 ** ADDRESS_SIZE - 1) of  std_logic_vector(width_ram-1 downto 0);
        signal tmp_ram: ram_type;
        constant var : integer  :=256;
        --create component right here
    component PLprocessing is
        generic(  DATA_SIZE    : integer:=32;
                        ADDRESS_SIZE : integer :=4
        port (
                clk                                  : in std_logic;
                en_in                            : in std_logic;
                input_data                      : in  std_logic_vector(DATA_SIZE - 1 downto 0);
                address_in                   : in std_logic_vector(ADDRESS_SIZE -1 downto 0);
                data_out                     : out std_logic_vector(DATA_SIZE -1 downto 0);
                ready                        : out std_logic
    end component PLprocessing;
    begin
        -- I/O Connections assignments
    mmap_pl : PLprocessing
                    generic map
                        (DATA_SIZE => C_S_AXI_DATA_WIDTH,
                         ADDRESS_SIZE => ADDRESS_SIZE
                    port map(
                        clk => S_AXI_ACLK,
                        en_in => en_ram,
                        input_data => slv_reg1,
                        address_in => address_in,
                        data_out => DataDone,
                        ready => ready_pl
        S_AXI_AWREADY    <= axi_awready;
        S_AXI_WREADY        <= axi_wready;
        S_AXI_BRESP        <= axi_bresp;
        S_AXI_BVALID        <= axi_bvalid;
        S_AXI_ARREADY    <= axi_arready;
        S_AXI_RDATA            <= axi_rdata;
        S_AXI_RRESP        <= axi_rresp;
        S_AXI_RVALID        <= axi_rvalid;
        -- Implement axi_awready generation
        -- axi_awready is asserted for one S_AXI_ACLK clock cycle when both
        -- S_AXI_AWVALID and S_AXI_WVALID are asserted. axi_awready is
        -- de-asserted when reset is low.
        process (S_AXI_ACLK)
        begin
          if rising_edge(S_AXI_ACLK) then
            if S_AXI_ARESETN = '0' then
              axi_awready <= '0';
            else
              if (axi_awready = '0' and S_AXI_AWVALID = '1' and S_AXI_WVALID = '1') then
                -- slave is ready to accept write address when
                -- there is a valid write address and write data
                -- on the write address and data bus. This design
                -- expects no outstanding transactions.
                axi_awready <= '1';
              else
                axi_awready <= '0';
              end if;
            end if;
          end if;
        end process;
        -- Implement axi_awaddr latching
        -- This process is used to latch the address when both
        -- S_AXI_AWVALID and S_AXI_WVALID are valid.
        begin
              axi_awaddr <= (others => '0');
            else
                -- Write Address latching
                axi_awaddr <= S_AXI_AWADDR;
              end if;
            end if;
          end if;
        end process;
        -- Implement axi_wready generation
        -- axi_wready is asserted for one S_AXI_ACLK clock cycle when both
        -- S_AXI_AWVALID and S_AXI_WVALID are asserted. axi_wready is
        begin
              axi_wready <= '0';
            else
              if (axi_wready = '0' and S_AXI_WVALID = '1' and S_AXI_AWVALID = '1') then
                  -- slave is ready to accept write data when
                  axi_wready <= '1';
              else
                axi_wready <= '0';
              end if;
            end if;
          end if;
        end process;
        -- Implement memory mapped register select and write logic generation
        -- The write data is accepted and written to memory mapped registers when
        -- axi_awready, S_AXI_WVALID, axi_wready and S_AXI_WVALID are asserted. Write strobes are used to
        -- select byte enables of slave registers while writing.
        -- These registers are cleared when reset (active low) is applied.
        -- Slave register write enable is asserted when valid address and data are available
        -- and the slave is ready to accept the write address and write data.
        slv_reg_wren <= axi_wready and S_AXI_WVALID and axi_awready and S_AXI_AWVALID ;
        variable loc_addr :std_logic_vector(OPT_MEM_ADDR_BITS downto 0);
        begin
              --slv_reg0 <= (others => '0');
              slv_reg1 <= (others => '0');
              slv_reg2 <= (others => '0');
              slv_reg3 <= (others => '0');
            else
              loc_addr := axi_awaddr(ADDR_LSB + OPT_MEM_ADDR_BITS downto ADDR_LSB);
              if (slv_reg_wren = '1') then
                case loc_addr is
                  when b"00" =>
                    for byte_index in 0 to (C_S_AXI_DATA_WIDTH/8-1) loop
                      if ( S_AXI_WSTRB(byte_index) = '1' ) then
                        -- Respective byte enables are asserted as per write strobes
                        -- slave registor 0
                        --slv_reg0(byte_index*8+7 downto byte_index*8) <= S_AXI_WDATA(byte_index*8+7 downto byte_index*8);
                      end if;
                    end loop;
                  when b"01" =>
                        -- slave registor 1
                        slv_reg1(byte_index*8+7 downto byte_index*8) <= S_AXI_WDATA(byte_index*8+7 downto byte_index*8);
                      end if;
                    end loop;
                  when b"10" =>
                        -- slave registor 2
                        slv_reg2(byte_index*8+7 downto byte_index*8) <= S_AXI_WDATA(byte_index*8+7 downto byte_index*8);
                      end if;
                    end loop;
                  when b"11" =>
                        -- slave registor 3
                        slv_reg3(byte_index*8+7 downto byte_index*8) <= S_AXI_WDATA(byte_index*8+7 downto byte_index*8);
                      end if;
                    end loop;
                  when others =>
                    --slv_reg0 <= slv_reg0;
                    slv_reg1 <= slv_reg1;
                    slv_reg2 <= slv_reg2;
                    slv_reg3 <= slv_reg3;
                end case;
              end if;
            end if;
          end if;
        end process;
        -- Implement write response logic generation
        -- The write response and response valid signals are asserted by the slave
        -- when axi_wready, S_AXI_WVALID, axi_wready and S_AXI_WVALID are asserted.
        -- This marks the acceptance of address and indicates the status of
        -- write transaction.
        begin
              axi_bvalid  <= '0';
              axi_bresp   <= "00"; --need to work more on the responses
            else
              if (axi_awready = '1' and S_AXI_AWVALID = '1' and axi_wready = '1' and S_AXI_WVALID = '1' and axi_bvalid = '0'  ) then
                axi_bvalid <= '1';
                axi_bresp  <= "00";
              elsif (S_AXI_BREADY = '1' and axi_bvalid = '1') then   --check if bready is asserted while bvalid is high)
                axi_bvalid <= '0';                                 -- (there is a possibility that bready is always asserted high)
              end if;
            end if;
          end if;
        end process;
        -- Implement axi_arready generation
        -- axi_arready is asserted for one S_AXI_ACLK clock cycle when
        -- S_AXI_ARVALID is asserted. axi_awready is
        -- de-asserted when reset (active low) is asserted.
        -- The read address is also latched when S_AXI_ARVALID is
        -- asserted. axi_araddr is reset to zero on reset assertion.
        begin
              axi_arready <= '0';
              axi_araddr  <= (others => '1');
            else
              if (axi_arready = '0' and S_AXI_ARVALID = '1') then
                -- indicates that the slave has acceped the valid read address
                axi_arready <= '1';
                -- Read Address latching
                axi_araddr  <= S_AXI_ARADDR;
              else
                axi_arready <= '0';
              end if;
            end if;
          end if;
        end process;
        -- Implement axi_arvalid generation
        -- axi_rvalid is asserted for one S_AXI_ACLK clock cycle when both
        -- S_AXI_ARVALID and axi_arready are asserted. The slave registers
        -- data are available on the axi_rdata bus at this instance. The
        -- assertion of axi_rvalid marks the validity of read data on the
        -- bus and axi_rresp indicates the status of read transaction.axi_rvalid
        -- is deasserted on reset (active low). axi_rresp and axi_rdata are
        -- cleared to zero on reset (active low).
        begin
              axi_rvalid <= '0';
              axi_rresp  <= "00";
            else
              if (axi_arready = '1' and S_AXI_ARVALID = '1' and axi_rvalid = '0') then
                -- Valid read data is available at the read data bus
                axi_rvalid <= '1';
                axi_rresp  <= "00"; -- 'OKAY' response
              elsif (axi_rvalid = '1' and S_AXI_RREADY = '1') then
                -- Read data is accepted by the master
                axi_rvalid <= '0';
              end if;
            end if;
          end if;
        end process;
        -- Implement memory mapped register select and read logic generation
        -- Slave register read enable is asserted when valid address is available
        -- and the slave is ready to accept the read address.
        slv_reg_rden <= axi_arready and S_AXI_ARVALID and (not axi_rvalid) ;
        --DataDone <= tmp_ram(conv_integer(0));
        process (slv_reg0, slv_reg1, DataDone, slv_reg3, axi_araddr, S_AXI_ARESETN, slv_reg_rden)
        begin
            -- Address decoding for reading registers
            loc_addr := axi_araddr(ADDR_LSB + OPT_MEM_ADDR_BITS downto ADDR_LSB);
            case loc_addr is
              when b"00" =>
                reg_data_out <= slv_reg0;
              when b"01" =>
                reg_data_out <= slv_reg1;
              when b"10" =>
                reg_data_out <= DataDone;
              when b"11" =>
                reg_data_out <= slv_reg3;
              when others =>
                reg_data_out  <= (others => '0');
            end case;
        end process;
        -- Output register or memory read data
        process( S_AXI_ACLK ) is
        begin
          if (rising_edge (S_AXI_ACLK)) then
            if ( S_AXI_ARESETN = '0' ) then
              axi_rdata  <= (others => '0');
            else
              if (slv_reg_rden = '1') then
                -- When there is a valid read address (S_AXI_ARVALID) with
                -- acceptance of read address by the slave (axi_arready),
                -- output the read dada
                -- Read address mux
                  axi_rdata <= reg_data_out;     -- register read data
              end if;
            end if;
          end if;
        end process;
        -- Add user logic here
        --slv_reg0 <= slv_reg1 + slv_reg2;
        --slv_reg0 <= "01000000000000000000000000000000";
    end arch_imp;
Teacher muzaffer
Re: receive 256 bits data from PS via axi lite slave
@mohamd17 256 bits fit into 8 32 bit slots; you have two ways of making 8 slots, one is to spread them across time, ie you implement a fifo in your PL block and every time you read the location, that transaction also pops the fifo and the next time you read it you get a new value.
Another option is to use 8 separate locations in your axi slave address space. Then the PL can have 8 separate outputs which get returned through separate registers and you can read them through different addresses on the PS side.
Teacher muzaffer
