sdl library porting on zc702
   we are run a code on zc702 board, we need the sdl library support for execution time, how can we add sdl library for the execution
Scholar sampatd
Re: sdl library porting on zc702
To add Libraries and Library paths in SDK, please refer to the link below:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_4/SDK_Doc/tasks/sdk_t_proj_libraries.htm
The eclipse based tutorial below will also help:
http://lazyfoo.net/SDL_tutorials/lesson01/windows/eclipse/index.php
 Thanks for reply
     i think adding library paths will work, when we run sdl or any library in the operating system,
   but i am working on petalinux which is on sdcard,
   tell me whether i need to compile library with arm linux gcc compiler and place in sdcard to provide path for project or
  do i need to do any thing for compilation..
please suggest me
Scholar sampatd
Are these libraries already compiled?
If you have pre-compiled libraries, you can check the following discussion:
http://forums.xilinx.com/t5/Embedded-Linux/Adding-pre-compiled-libraries-to-Petalinux-rootfs/td-p/501500
http://www.xilinx.com/support/answers/55976.html
If not, you will need to compile these libraries using 'arm-xilinx-linux-gnueabi' toolchain. I have attached a document that describes the procedure to create a shared object file (*.so) using SDK.
You can also create the libraries in petalinux using petalinux-create command
