section to memory region mapping
I have some issue when assigning section to memory  region mapping in lsscript.ld
The elf mapping is as following:
text data bss dec hex filename
98616 8188 5188 111992 1b578 CZ5C2010A_uBlaze_POD.elf
While the memory available is
 bram0 64k
bram1 64k
because text is ~84k , I can't handle the assigning of section to memory without getting linker error os size.
Please advise,
Ran
Scholar sampatd
Re: section to memory region mapping
You can probably try assigning the text sections to different regions of memory by editing the linker script. Check the AR below:
http://www.xilinx.com/support/answers/21639.html
Thanks for the link, But I don't see any .text file in my source directory.
I suppose I should divide that .text file into 3 seperate files, but where is it ?
Ran
Scholar sampatd
How many relocatable object files (*.o) do you have in the Debug/Src folder of your application?
Each of the object file has a .text section. If you have multiple object files (*.o) you can split the text section and place them in different memories (if you have any) as per the AR.
