Visitor hyphen
should tvalid de-assert after tlast is asserted?
Hi everyone,
Considering an 'axi stream fifo' is connecting to an s2mm of axi dma, should the tvalid de-assert after tlast is asserted?
here is the reason caused the problem in my design and temporary solution.
thanks, everyone's valuable discussion.
I check the customized IP I used. the block design was like this:
 customer IP(data port) ->   (S)axi stream fifo(M)  -> (s2mm)axi_dma ....
However, the port of the 'customer IP(data port) ' is sort of a slave port, which is always detecting an input then put data on bus and assert tvalid.
So, that why my dma read always halts somehow. As discussed in this thread, a slave to slave of axi_stream_fifo will never work.
Now, my solution is to inserting another logic between two slaves and keep previous 'tvalid' and data bus.
- check fifo occupation link:   customer IP(data port) <- [ extera logic (if not full)]  <- (S)axi stream fifo(M)
- tvalid and data link:             customer IP(data port) -> (S)axi stream fifo(M)
The [ extera logic] detect the fifo_occupation of the 'axi stream fifo' and assert a 'not full' to the  'customer IP(data port) '.
Now, the dma reads smoothly.
Scholar richardhead
Re: should tvalid de-assert after tlast is asserted?
@drjohnsmith
"is that correct or a typo ?"
Correct. You are allowed to reflect tvalid back via tready, but not the other way, to prevent deadlocks. Its in the AXI spec
AXI4-stream spec, 2.2.1:
"A master is not permitted to wait until TREADY is asserted before asserting TVALID. Once
TVALID is asserted it must remain asserted until the handshake occurs.
A slave is permitted to wait for TVALID to be asserted before asserting the corresponding
TREADY."
This is true of all ready/valid handshaking across AXI, not just streaming (each channel in AXI4 is effectively the same as an axi-stream interface)
Teacher drjohnsmith
https://www.xilinx.com/support/documentation/ip_documentation/axis_interconnect/v1_1/pg035_axis_interconnect.pdf Tvalid from the master indicates that the master is driving valid data . Tlast from the master shows this is the last data of the 'block'. So I'd say that if data is valid, then Tvalid is true, no matter what the state of Tlast. But, look at the doc for the fifo your using.....
Visitor hyphen
Thanks for the reply.
The reason of my question is that I customized an axi-stream-master to feed data to s2mm, tlast desserts every N transfers but DMA reading in SDK still halt somehow. So, I am trying looking for the bugs.
Now, the implementation is that tvalid desserts when tready from s2mm desserts then every 32 tlast assert.
The ali waveform shows: tlast works and does assert every 32, but the tready from s2mm never de-asserts so that my tvalid never de-asserts either. Is this normal?
Scholar richardhead
tvalid indicates that there is valid data (which covers tdata, tid, tlast etc). There is no requirement for it to drop after tlast. Tlast indicates the end of one packet. To force back-pressure, you de-assert tready. It is actually illegal to de-assert tvalid once it has been asserted without tready being asserted.
Its also illegal to tie tvalid to tready, but tready is allowed to be tied to tvalid.
Why not post some code or a waveform?
Visitor hyphen
thanks. will post the sch, codes and waveform once I get the board and run it again.
Teacher drjohnsmith
"its also illegal to tie tvalid to tready, but tready is allowed to be tied to tvalid"
Teacher drjohnsmith
whats the simulation say ?
Scholar richardhead
@drjohnsmith
TREADY."
You should also be aware that a combinatorial implementation of looping TVALID to TREADY is not allowed.
I only have version 1.0 of the streaming spec but it says 2.7.1 Clocks "...All output signal changes must occur after the rising edge of ACLK."
The normal AXI spec is a bit clearer "there must be no combinatorial paths between input and output signals."
Basically once you start driving a VALID, it and the associated data signals cannot change unless accepted as indicated by the associated READY being asserted.  If READY de-asserts you should leave everything as it is including the in block and total blocks counters.
Teacher drjohnsmith
Ok, yes agree with that
it was just the words you typed, seem to say that the signlas were bi directional, which they are not..
""its also illegal to tie tvalid to tready, but tready is allowed to be tied to tvalid""
Visitor hyphen
I check the customized IP I used. actually, the block design was like this:
