Observer wen119at
sos....Problem with MPMC_Clk0, InitDone remains LOW
Hi everyone,
I am using EDK to communicate my IP core with DDR3 via MPMC using two NPI ports.
The board I am using is ML605.
By default, MPMC_Clk0 which is the MPMC system clock is set to 200MHz.
For some reason, my IP has to communicate with DDR3 under lower frequency (100MHz).
However, it doesn't work.
MPMC_InitDone remains low.... and the same with PIM0_InitDone and PIM1_InitDone.
It seems that the memory initialization is never finished.
What I have changed are MPMC_Clk0,  MPMC_Clk_Mem and MPMC_Clk_Rd_Base :
in MHS file:
before change the Clock frequency(default with MPMC_Clk0=200MHz):
BEGIN mpmc
PORT MPMC_Clk0 = clk_200_0000MHzMMCM0
PORT MPMC_Clk_200MHz = clk_200_0000MHzMMCM0
PORT MPMC_Clk_Mem = clk_400_0000MHzMMCM0
PORT MPMC_Clk_Rd_Base = clk_400_0000MHzMMCM0_nobuf_varphase
END
BEGIN clock_generator
PARAMETER INSTANCE = clock_generator_0
PARAMETER C_CLKIN_FREQ = 200000000
PARAMETER C_CLKOUT0_FREQ = 100000000
PARAMETER C_CLKOUT0_PHASE = 0
PARAMETER C_CLKOUT0_GROUP = MMCM0
PARAMETER C_CLKOUT0_BUF = TRUE
PARAMETER C_CLKOUT1_FREQ = 200000000
PARAMETER C_CLKOUT1_PHASE = 0
PARAMETER C_CLKOUT1_GROUP = MMCM0
PARAMETER C_CLKOUT1_BUF = TRUE
PARAMETER C_CLKOUT2_FREQ = 400000000
PARAMETER C_CLKOUT2_PHASE = 0
PARAMETER C_CLKOUT2_GROUP = MMCM0
PARAMETER C_CLKOUT2_BUF = TRUE
PARAMETER C_CLKOUT3_FREQ = 400000000
PARAMETER C_CLKOUT3_PHASE = 0
PARAMETER C_CLKOUT3_GROUP = MMCM0
PARAMETER C_CLKOUT3_BUF = FALSE
PARAMETER C_CLKOUT3_VARIABLE_PHASE = TRUE
PARAMETER C_PSDONE_GROUP = MMCM0
PARAMETER C_EXT_RESET_HIGH = 1
PARAMETER HW_VER = 4.01.a
PORT CLKIN = CLK_S
PORT CLKOUT0 = clk_100_0000MHzMMCM0
PORT CLKOUT1 = clk_200_0000MHzMMCM0
PORT CLKOUT2 = clk_400_0000MHzMMCM0
PORT CLKOUT3 = clk_400_0000MHzMMCM0_nobuf_varphase
PORT PSCLK = clk_200_0000MHzMMCM0
PORT PSEN = MPMC_DCM_PSEN
PORT PSINCDEC = MPMC_DCM_PSINCDEC
PORT PSDONE = MPMC_DCM_PSDONE
PORT RST = sys_rst_s
PORT LOCKED = Dcm_all_locked
END
after change the Clock frequency(with MPMC_Clk0=100MHz):
BEGIN mpmc
PORT MPMC_Clk0 = clk_100_0000MHzMMCM0
PORT MPMC_Clk_Mem = clk_200_0000MHzMMCM0
PORT MPMC_Clk_Rd_Base = DDR3_SDRAM_MPMC_Clk_Rd_Base
END
PARAMETER C_CLKOUT2_FREQ = 200000000
PARAMETER C_CLKOUT2_BUF = FALSE
PARAMETER C_CLKOUT2_VARIABLE_PHASE = TRUE
PARAMETER C_CLKOUT3_FREQ = 50000000
PARAMETER C_CLKOUT3_BUF = TRUE
PORT CLKIN = CLK_S
PORT CLKOUT2 = DDR3_SDRAM_MPMC_Clk_Rd_Base
PORT CLKOUT3 = my_custom_ip_0_Clock_50MHz
END
The relationship I found in the user guide is :
The MPMC_Clk_Rd_Base is the same frequency as MPMC_Clk_Mem, and should not be buffered to global routing.
The MPMC_Clk_Mem port drives the memory clock. MPMC_Clk0 is half the memory clock frequency and is synchronous to MPMC_Clk_Mem. Another port called MPMC_Clk_200MHz requires a 200 MHz clock to drive the IDELAY elements, but this clock can be asynchronous to all other clocks.
I have made the changes to MPMC_Clk0,  MPMC_Clk_Mem and MPMC_Clk_Rd_Base according to the user guide, but DDR3 is still not responding (InitDone remains low).
I am wondering if there is anything else that should be changed to make MPMC work at the lower frequency (100MHz).
Is there a frequency limitation to MPMC_Clk0...only 200MHz?
Thanks for any hints.
Re: sos....Problem with MPMC_Clk0, InitDone remains LOW
DDR3 has a minimum frequency of 300MHz. I suggest creating a design using the Base System Builder wizard to create the ML605 design to note the frequency ratios.
