standalone mode  ps can not get PL to PS interrupt
testing  zcu106  a53  standalone mode  PL to PS interrupt, base on  xscugic_example.c and modify  soft interrput  to irq0(121U) , an Axi register to triggle the signal to irq0.   Connecting in pl is below:
modified xscugic_example.c is below:
/****************************************************************************** * * Copyright (C) 2010 - 2015 Xilinx, Inc. All rights reserved. * * Permission is hereby granted, free of charge, to any person obtaining a copy * of this software and associated documentation files (the "Software"), to deal * in the Software without restriction, including without limitation the rights * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell * copies of the Software, and to permit persons to whom the Software is * furnished to do so, subject to the following conditions: * * The above copyright notice and this permission notice shall be included in * all copies or substantial portions of the Software. * * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL * XILINX BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF * OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE * SOFTWARE. * * Except as contained in this notice, the name of the Xilinx shall not be used * in advertising or otherwise to promote the sale, use or other dealings in * this Software without prior written authorization from Xilinx. * ******************************************************************************/ /******************************************************************************/ /** * * @file xscugic_example.c * * This file contains a design example using the Interrupt Controller driver * (XScuGic) and hardware device. Please reference other device driver examples * to see more examples of how the intc and interrupts can be used by a software * application. * * @note * * None * * <pre> * * MODIFICATION HISTORY: * Ver Who Date Changes * ----- ---- -------- ---------------------------------------------------- * 1.00a drg 01/18/10 First release * </pre> ******************************************************************************/ /***************************** Include Files *********************************/ #include <stdio.h> #include <stdlib.h> #include "xil_io.h" #include "xil_exception.h" #include "xparameters.h" #include "xil_cache.h" #include "xil_printf.h" #include "xil_types.h" #include "xscugic.h" /************************** Constant Definitions *****************************/ /* * The following constants map to the XPAR parameters created in the * xparameters.h file. They are defined here such that a user can easily * change all the needed parameters in one place. */ #define INTC_DEVICE_ID XPAR_SCUGIC_0_DEVICE_ID #define INTC_DEVICE_INT_ID XPAR_FABRIC_VCU_0_VCU_HOST_INTERRUPT_INTR /**************************** Type Definitions *******************************/ /***************** Macros (Inline Functions) Definitions *********************/ /************************** Function Prototypes ******************************/ int ScuGicExample(u16 DeviceId); int SetUpInterruptSystem(XScuGic *XScuGicInstancePtr); void DeviceDriverHandler(void *CallbackRef); /************************** Variable Definitions *****************************/ XScuGic InterruptController; /* Instance of the Interrupt Controller */ static XScuGic_Config *GicConfig; /* The configuration parameters of the controller */ /* * Create a shared variable to be used by the main thread of processing and * the interrupt processing */ volatile static int InterruptProcessed = FALSE; static void AssertPrint(const char8 *FilenamePtr, s32 LineNumber){ xil_printf("ASSERT: File Name: %s ", FilenamePtr); xil_printf("Line Number: %d\r\n",LineNumber); } void ActivateHwIRQ(u32 intr_src) { Xil_Out32(intr_src, 0x1); } void DeActivateHwIRQ(u32 intr_src) { Xil_Out32(intr_src, 0); } /*****************************************************************************/ /** * * This is the main function for the Interrupt Controller example. * * @param None. * * @return XST_SUCCESS to indicate success, otherwise XST_FAILURE. * * @note None. * ****************************************************************************/ int main(void) { int Status; /* * Setup an assert call back to get some info if we assert. */ Xil_AssertSetCallback(AssertPrint); xil_printf("GIC Example Test\r\n"); /* * Run the Gic example , specify the Device ID generated in xparameters.h */ Status = ScuGicExample(INTC_DEVICE_ID); if (Status != XST_SUCCESS) { xil_printf("GIC Example Test Failed\r\n"); return XST_FAILURE; } xil_printf("Successfully ran GIC Example Test\r\n"); return XST_SUCCESS; } /*****************************************************************************/ /** * * This function is an example of how to use the interrupt controller driver * (XScuGic) and the hardware device. This function is designed to * work without any hardware devices to cause interrupts. It may not return * if the interrupt controller is not properly connected to the processor in * either software or hardware. * * This function relies on the fact that the interrupt controller hardware * has come out of the reset state such that it will allow interrupts to be * simulated by the software. * * @param DeviceId is Device ID of the Interrupt Controller Device, * typically XPAR_<INTC_instance>_DEVICE_ID value from * xparameters.h * * @return XST_SUCCESS to indicate success, otherwise XST_FAILURE * * @note None. * ******************************************************************************/ int ScuGicExample(u16 DeviceId) { int Status; DeActivateHwIRQ(0xa0001000); /* * Initialize the interrupt controller driver so that it is ready to * use. */ GicConfig = XScuGic_LookupConfig(DeviceId); if (NULL == GicConfig) { return XST_FAILURE; } Status = XScuGic_CfgInitialize(&InterruptController, GicConfig, GicConfig->CpuBaseAddress); if (Status != XST_SUCCESS) { return XST_FAILURE; } /* * Perform a self-test to ensure that the hardware was built * correctly */ Status = XScuGic_SelfTest(&InterruptController); if (Status != XST_SUCCESS) { return XST_FAILURE; } /* * Setup the Interrupt System */ Status = SetUpInterruptSystem(&InterruptController); if (Status != XST_SUCCESS) { return XST_FAILURE; } /* * Connect a device driver handler that will be called when an * interrupt for the device occurs, the device driver handler performs * the specific interrupt processing for the device */ Status = XScuGic_Connect(&InterruptController, INTC_DEVICE_INT_ID, (Xil_ExceptionHandler)DeviceDriverHandler, (void *)&InterruptController); if (Status != XST_SUCCESS) { return XST_FAILURE; } /* * Enable the interrupt for the device and then cause (simulate) an * interrupt so the handlers will be called */ XScuGic_Enable(&InterruptController, INTC_DEVICE_INT_ID); xil_printf("Enabled IRQ id:%d\n\r", INTC_DEVICE_INT_ID); /* * Simulate the Interrupt */ ActivateHwIRQ(0xa0001000); xil_printf("active irp \r\n"); // DeActivateHwIRQ(0xa0001000); // Status = XScuGic_SoftwareIntr(&InterruptController, // INTC_DEVICE_INT_ID, // XSCUGIC_SPI_CPU0_MASK); // if (Status != XST_SUCCESS) { // return XST_FAILURE; // } /* * Wait for the interrupt to be processed, if the interrupt does not * occur this loop will wait forever */ while (1) { /* * If the interrupt occurred which is indicated by the global * variable which is set in the device driver handler, then * stop waiting */ if (InterruptProcessed) { break; } } return XST_SUCCESS; } /******************************************************************************/ /** * * This function connects the interrupt handler of the interrupt controller to * the processor. This function is seperate to allow it to be customized for * each application. Each processor or RTOS may require unique processing to * connect the interrupt handler. * * @param XScuGicInstancePtr is the instance of the interrupt controller * that needs to be worked on. * * @return None. * * @note None. * ****************************************************************************/ int SetUpInterruptSystem(XScuGic *XScuGicInstancePtr) { /* * Connect the interrupt controller interrupt handler to the hardware * interrupt handling logic in the ARM processor. */ Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_INT, (Xil_ExceptionHandler) XScuGic_InterruptHandler, XScuGicInstancePtr); /* * Enable interrupts in the ARM */ Xil_ExceptionEnable(); return XST_SUCCESS; } /******************************************************************************/ /** * * This function is designed to look like an interrupt handler in a device * driver. This is typically a 2nd level handler that is called from the * interrupt controller interrupt handler. This handler would typically * perform device specific processing such as reading and writing the registers * of the device to clear the interrupt condition and pass any data to an * application using the device driver. Many drivers already provide this * handler and the user is not required to create it. * * @param CallbackRef is passed back to the device driver's interrupt * handler by the XScuGic driver. It was given to the XScuGic * driver in the XScuGic_Connect() function call. It is typically * a pointer to the device driver instance variable. * In this example, we do not care about the callback * reference, so we passed it a 0 when connecting the handler to * the XScuGic driver and we make no use of it here. * * @return None. * * @note None. * ****************************************************************************/ void DeviceDriverHandler(void *CallbackRef) { /* * Indicate the interrupt has been processed using a shared variable */ xil_printf("irq happened \r\n"); InterruptProcessed = TRUE; }
Unfortunately ,  ps can not get the intterrupt .  i have checked the signal is triggled in system_ila_0.
Is there anything to config?  Any point is helpful , thanks.
Re: standalone mode  ps can not get PL to PS interrupt
Hi linken_mu@163.com ,
Looks like the custom IP interrupt port is not interrupt typed by definition which is connected to PS IP's irq port.
You need to make sure in properties of custom IP interrupt port is of irq type def.
Praveen
problem is solved . after setting interrupt's trigger(raising edge), ps get the interrupt. Thanks for attentions.
