Visitor singularwoo
use iomodule together with other ips in microblaze system
I am using the microblaze processor. Now I need ips such as iobus, iic, uart. But I can't find an iobus ip alone. The ip IOModule does include the iobus function, but when I build a block design with microblaze, iomodule and other ips, the sysyem failed. What's wrong of my design? And is there any other ways that I can use iobus with other ips in microblaze design?
Thanks!
Re: use iomodule together with other ips in microblaze system
Hi @singularwoo,
You need to enable IO bus in IO module configuration under System tab.
Refer to figure 4-2 in https://www.xilinx.com/support/documentation/ip_documentation/iomodule/v3_0/pg111-iomodule.pdf
Praveen
