what 's wrong with the codd .help .
Hi all
i  tryed to instance a uartlite and add a GPIO ip , i have been finished the software code .when i click the  build all aplication  After i generated the netist ,the error happened . i tryed many times ,but  did not work.can you give me a hand ? thank you very much.
 The following is the contents of the error .
/cygdrive/c/EDK/gnu/microblaze/nt/bin/../lib/gcc/microblaze/3.4.1/../../../../microblaze/bin/ld.real: region ilmb_cntlr_dlmb_cntlr is full (TestApp_Memory/executable.elf section .text)
/cygdrive/c/EDK/gnu/microblaze/nt/bin/../lib/gcc/microblaze/3.4.1/../../../../microblaze/bin/ld.real: section .init [00000050 -> 00000077] overlaps section .text [00000050 -> 0000e173]
/cygdrive/c/EDK/gnu/microblaze/nt/bin/../lib/gcc/microblaze/3.4.1/../../../../microblaze/bin/ld.real: section .fini [00000078 -> 00000093] overlaps section .text [00000050 -> 0000e173]
/cygdrive/c/EDK/gnu/microblaze/nt/bin/../lib/gcc/microblaze/3.4.1/../../../../microblaze/bin/ld.real: section .rodata [00000094 -> 000007ff] overlaps section .text [00000050 -> 0000e173]
/cygdrive/c/EDK/gnu/microblaze/nt/bin/../lib/gcc/microblaze/3.4.1/../../../../microblaze/bin/ld.real: section .data [00000800 -> 00000f57] overlaps section .text [00000050 -> 0000e173]
/cygdrive/c/EDK/gnu/microblaze/nt/bin/../lib/gcc/microblaze/3.4.1/../../../../microblaze/bin/ld.real: section .ctors [00000f58 -> 00000f5f] overlaps section .text [00000050 -> 0000e173]
/cygdrive/c/EDK/gnu/microblaze/nt/bin/../lib/gcc/microblaze/3.4.1/../../../../microblaze/bin/ld.real: section .dtors [00000f60 -> 00000f67] overlaps section .text [00000050 -> 0000e173]
/cygdrive/c/EDK/gnu/microblaze/nt/bin/../lib/gcc/microblaze/3.4.1/../../../../microblaze/bin/ld.real: section .jcr [00000f68 -> 00000f6b] overlaps section .text [00000050 -> 0000e173]
collect2: ld returned 1 exit status
make: *** [TestApp_Memory/executable.elf] Error 1
Re: what 's wrong with the codd .help .
Is it possible that you add UART-IP and GPIO-IP without generating addresses?
Greetings
M.Rapp
Merry Christmas
Greetings
M.Rapp
Merry Christmas
thank you very much , i have been  already solved  the problem which caused by my careless that i didn't include the proper header file .
thank you all the same !! merry christmas!!!
