xc7k325t(-2 or -1) microblaze mips estimate
hi,i make a micro blaze in xc7k325t(-2) to take some calculation.i find some material in https://www.xilinx.com/products/design-tools/microblaze.html#processorDetails.
so, how can i get the max dmips of xc7k325t(-2) ,do you have some datasheets to reference?and is the dmips relation to the Resource use?
thinks.
Voyager
Voyager
Re: xc7k325t(-2 or -1) microblaze mips estimate
I am not sure you can get reliable max dmips values from a datasheet.  The microblaze IP core is highly configurable which will greatly impact the max dmips for that implementation of the processor.  Typically a microblaze implementation with a higher dmips will use more resources.  Of course a microblaze that is configured with a hard floating point unit will use more resources without performing any higher dmips.
Ted Booth - Tech. Lead FPGA Design Engineer
www.designlinxhs.com
