Observer ahmedkhazal
xilinx zynq processors
hi friends
please is there anyone can help me to connect multi - zynq processors (three zynq cores) in the same block design ?
how can I dell  with those  processors in the SDK tool ?
thanks for everyone
Re: xilinx zynq processors
Hi @ahmedkhazal,
Yes this is possible. But if you are using a Zynq device it would be a waste not to use the Zynq cores. The zynq is an hard IP (is already in the device) while the MicroBlaze (MB) is a soft IP (needs to be programmed -> use FPGA resources)
You can also use both MB and zynq cores.
Florent
Florent
Hi @ahmedkhazal,
You can have only one zynq in a project. The Zynq IP represents your PS part which has multiple cores.
Then, in SDK you select which core you want to target.
The Zynq IP represents what I have highlighted, it contains the 2 cortex-A9 cores (for zynq-7000):
Hope that helps,
Florent
Florent
thanks friend ,is that possible to use multi-microblaze processors instead of zynq processors
Hi @ahmedkhazal,
Florent
Florent
