xilkernel on vivado
hello,
i'm new with xilkernel and looking for documentation, user guides or examples i found the lastest are from ISE 14.4.
Due the device I'm using I need vivado to implement the design but there is not any resource for xilkernel for vivado or I didn't found it.
Any help or advice for porting the UG758 to vivado?
regards.
Re: xilkernel on vivado
Xilkernel has been replaced by FreeRTOS for Zynq. This can be obtained at the link below:
http://www.freertos.org/Interactive_Frames/Open_Frames.html?http://interactive.freertos.org/entries/21706962-xilinx-freertos-port-for-zynq
Unzip the package and...
copy the freertos_zynq_v1_00_a into:
<XILINX INSTALL DIRECTORY>\ISE_DS\EDK\sw\lib\bsp
copy the contents on the sw_apps (freertos_blink_led and freertos_hello_world) folder into:
<XILINX INSTALL DIRECTORY>\ISE_DS\EDK\sw\lib\sw_apps
Now when you create a new Zynq BSP, toy will be able to choose the freertos bsp
Note: you can also add the bsp folder from the zip to the repository in your project, but
you will have to do this for every project.....
Thanks and Regards
Balkrishan
hello balkris,
I had read that in other post but the problem is I want to run xilkernell on kintex 7 devices without arm in microblaze.
So I imagine I have to switch back to ISE...
thanks.
regards.
