xtime_l.h file IP
What is the IP for the xtime_l.h header file ?
Re: xtime_l.h file IP
It use for measuring time in a bare-metal Zynq application. Here is example
#include <stdio.h> #include "platform.h" #include "xparameters.h" #include "xtime_l.h" void print(char *str); int main() { XTime tStart, tEnd; init_platform(); XTime_GetTime(&tStart); print("Hello World\n\r"); XTime_GetTime(&tEnd); printf("Output took %llu clock cycles.\n", 2*(tEnd - tStart)); printf("Output took %.2f us.\n", 1.0 * (tEnd - tStart) / (COUNTS_PER_SECOND/1000000)); return 0; }
Thanks and Regards
Balkrishan
Hi Balkrishan,
I have design on Artix-7 board (AC705) which comprises ISE as TOP module and EDK as sub-module, in which imaging related IPs.
Now, we have added AXI timer (version 1.03a).
Header file: "xtime_l.h"
When I am trying to add this header file in this IP (SDK) I am getting the below error.
"Description Resource Path Location Type
fatal error: xtime_l.h: No such file or directory main.c /timer/src line 4 C/C++ Problem"
I want to calculate time for particular process.
I am not familiar with bare-metal Zynq application.
So, what is bare-metal Zynq application?
Thank You.
Vrujal
Respected Balkrishan,
I have the below functionality working with Bare Metal, but my application uses FreeRTOS in Xilinx, and I am unable to use the time functionality owing to some parameters for sleep timers not declared in xparameters.h file as opposed to be seen with Bare Metal BSP include files.
So, could you please help me to know how can we use this functionality with the FreeRTOS application in BSP ?
Yours Sincerely,
Romin
