Visitor mikoz
zcu102 interrupt (newbie question)
I wish to sit in a loop waiting for an external signal to run a process on petalinux.  Once I receive the signal, the process will run.  Basically, create a gate for a process to run.  The external signal can be a logic signal of any voltage/logic type that I specify.
I can do this gating in either C code or with petalinux commands (if possible).
Is this as simple as using the GPIO pins? Is there a simple process to enable this?  Thanks.
thanks!
