zynq 7035 uartlite can not entry interrupt
 zynq 7035 PL extends a uartlite to send and receive data by interrupt mode.  I shorten TX pin and Rx pin  then send data, but can't enter  interrupt anyway. The sending data function  and hardware has been tested by polling mode, no problem. I don't know why I can't get in  interruption.
void InitDevice(void)
XUartLite_WriteReg(XPAR_AXI_UARTLITE_0_BASEADDR,XUL_CONTROL_REG_OFFSET,
                               XUL_CR_FIFO_RX_RESET|XUL_CR_FIFO_TX_RESET|XUL_CR_ENABLE_ITR);
void InterruptHandle(void)
     print("InterruptHandle Scueess!\r\n");
void InitInterruptSystem()
int Status;
XScuGic_Config *GicIntcConfig; //GIC config
Xil_ExceptionInit();
GicIntcConfig = XScuGic_LookupConfig(INTC_DEVICE_ID);
if (NULL == GicIntcConfig)
print("XScuGic_LookupConfig Failure\n\r");
Status = XScuGic_CfgInitialize(&GicInstancePtr, GicIntcConfig,GicIntcConfig->CpuBaseAddress);
if (Status != XST_SUCCESS)
print("XScuGic_CfgInitialize Failure\n\r");
XScuGic_Connect(&GicInstancePtr, UARTLITE_INT_IRQ_ID,
(Xil_InterruptHandler)InterruptHandle, //set up the uartlite interrupt
(void *)0);
XScuGic_Enable(&GicInstancePtr, UARTLITE_INT_IRQ_ID);//enable the interrupt for the uartlite at GIC
Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_INT,
(Xil_ExceptionHandler)XScuGic_InterruptHandler,//connect to the hardware
&GicInstancePtr);
Xil_ExceptionEnable();
int main()
uint8 u8ModDataAry[2] ={cmdGetConfig,flagModInstallMethod} ;
InitDevice();
InitInterruptSystem();
while(1)
ump_pUart0->SendCfgData(u8ModDataAry,0x02);
Delay();
Scholar jg_bds
Re: zynq 7035 uartlite can not entry interrupt
I can't follow that software stuff...
Did you re-configure the interrupt sensitivity? You can't leave it at the default value.
-Joe G.
Scholar jg_bds
-Joe G.
thanks for your reply,Joe. Do you mean that I should re-config the interrupt trigger type?the default value is high-level active,but the uart lite interrupt need rising edge type?
Scholar jg_bds
Yes: the UART IP is using an edge, but the interrupt controller in the PS may be expecting a level. Re-configure the PS interrupt controller to expect an edge, if it's not already so configured.
You should be able to quickly check the current contents of the relevant register, to confirm if this is the issue:
-Joe G.
Hi,Joe.I take your suggestion,re-config the trigger type to edge trigger type,then can  enter interrupt. But I get a new problem.I did not shorten TX and RX,when  i send data ,the FPGA also enter into interrupt.This  is not normal,the RX did not receive any data ,it can not enter interrupt,even I do not send data ,the system enter interrupt too. I can not  get this why did it happen?
XScuGic_SetPriorityTriggerType(&GicInstancePtr, UARTLITE_INT_IRQ_ID,
0xA0, 0x3);// b11 Rising edge sensitive
int main()
InitDevice();
us_pUart0->Init();
ump_pUart0->Init();
while(1)
Scholar jg_bds
This situation should be unreasonable.I do not send or receive data, the sysytem should not enter the interruption. In general, it is unrelated to sending data .when uart received then enter interruption.how to config to meet my application.ONLY the uart RECEIVE data then enter interrupt
Scholar jg_bds
I'm not sure why you're getting unexpected interrupts. If it were me, I'd put an ILA on the interrupt line from the UART IP to see if spurious interrupts were coming from it. If there are, you need to pursue that; if there aren't, there's a problem with the GIC configuration and/or the interrupt handler.
That aside, you can't get the behavior you want by using the UART Lite IP: it will send an interrupt when any of the circumstances arise that can cause an interrupt. You cannot configure it so that only one circumstance (e.g., data received only) actually causes an interrupt. For that kind of flexibility, you need to start over and use the 16550 UART IP instead of the UART Lite IP. See PG143.
-Joe G.
