ERROR: [Constraints 18-1000] using the HLS
INFO: [Route 35-77] Router completed with failures. Please check the log file for Critical Warnings and run report_route_status for a summary of routing status.
ERROR: [Constraints 18-1000] Routing results verification failed due to partially-conflicted nets (Up to first 10 of violated nets):  pfm_top_i/dynamic_region/interconnect_aximm_host/inst/s00_entry_pipeline/s00_si_converter/inst/converter.wrap_narrow_inst/gen_thread_loop[0].r_unshelve_reg_n_0_[0] pfm_top_i/dynamic_region/memory_subsystem/inst/memory/ddr4_mem01/inst/u_ddr4_mem_intfc/u_ddr_mc/u_ddr_mc_ecc/u_ddr_mc_ecc_ri_xor/dReg_reg[4][46] pfm_top_i/dynamic_region/pcaf_fpga_1/inst/grp_linear_knn_compute_fu_2064/dist_calc_or1_U0/pcaf_fpga_mul_32s_32s_56_2_1_U2123/pcaf_fpga_pcaf_fpga_mul_32s_32s_56_2_1_MulnS_0_U/tmp_product/P[7] pfm_top_i/dynamic_region/interconnect_aximm_host/inst/s00_entry_pipeline/s00_mmu/inst/r_sreg/skid_buffer_reg_n_0_[1281] pfm_top_i/dynamic_region/interconnect_aximm_host/inst/s00_entry_pipeline/s00_si_converter/inst/converter.wrap_narrow_inst/gen_thread_loop[0].r_payld_fifo/gen_thread_loop[0].r_shelf_reg[0][579][510] pfm_top_i/dynamic_region/interconnect_aximm_host/inst/s00_entry_pipeline/s00_si_converter/inst/converter.wrap_narrow_inst/gen_thread_loop[1].r_payld_fifo/cmd_fifo/m_valid_i pfm_top_i/dynamic_region/interconnect_aximm_host/inst/s00_entry_pipeline/s00_si_converter/inst/converter.wrap_narrow_inst/gen_thread_loop[1].r_payld_fifo/r_payld_reg_reg[64] pfm_top_i/dynamic_region/memory_subsystem/inst/memory/ddr4_mem01/inst/u_ddr4_mem_intfc/u_ddr_cal_top/c0_ddr4_rd_data_phy2mc[44] pfm_top_i/dynamic_region/memory_subsystem/inst/memory/ddr4_mem01/inst/u_ddr4_mem_intfc/u_ddr_cal_top/c0_ddr4_rd_data_phy2mc[47] pfm_top_i/dynamic_region/memory_subsystem/inst/memory/ddr4_mem01/inst/u_ddr4_mem_intfc/u_ddr_cal_top/c0_ddr4_rd_data_phy2mc[437]
Time (s): cpu = 19:37:55 ; elapsed = 07:30:09 . Memory (MB): peak = 23200.176 ; gain = 1051.887 ; free physical = 32492 ; free virtual = 45756
Routing Is Done.
INFO: [Common 17-83] Releasing license: Implementation
465 Infos, 361 Warnings, 43 Critical Warnings and 1 Errors encountered.
route_design completed successfully
route_design: Time (s): cpu = 19:43:11 ; elapsed = 07:49:58 . Memory (MB): peak = 23200.176 ; gain = 1051.887 ; free physical = 32477 ; free virtual = 45741
INFO: [Timing 38-480] Writing timing data to binary archive.
Writing placer database...
Writing XDEF routing.
Writing XDEF routing logical nets.
Writing XDEF routing special nets.
Write XDEF Complete: Time (s): cpu = 00:03:37 ; elapsed = 00:01:12 . Memory (MB): peak = 23200.176 ; gain = 0.000 ; free physical = 28602 ; free virtual = 45071
INFO: [Common 17-1381] The checkpoint '/home/xiaojia.song/SDAccel_Examples_2018_2/getting_started/host/PCAF_FPGA_sub_v2s2sub45_BFS_32_05/_x/link/vivado/prj/prj.runs/impl_1/pfm_top_wrapper_routed_error.dcp' has been generated.
write_checkpoint: Time (s): cpu = 00:08:19 ; elapsed = 00:07:07 . Memory (MB): peak = 23200.176 ; gain = 0.000 ; free physical = 31508 ; free virtual = 45498
ERROR: [Common 17-39] 'route_design' failed due to earlier errors.
INFO: [Common 17-206] Exiting Vivado at Fri Jan 18 11:48:22 2019...
I got this error when run the routing for my C++ code.
There isn't enougth information to let me know which fucntion in my C++ code cause this issue.
Do I need to change the vivado optimization strategy and how in the xocc compiler?
Re: ERROR: [Constraints 18-1000] using the HLS
Hi, @mathmaxsean ,
You can check whether the routed dcp is generated.
If the the routed dcp exists, you can try to open_checkpoint of this routed dcp in Vivado GUI to get the further information.
