Error while running xbinst command
I executed the following command to install the vcu1525 files needed for the deployment machine.
$mkdir /opt/dsa/xilinx_vcu1525_dynamic_5_1
$ cd /opt/dsa/xilinx_vcu1525_dynamic_5_1
$ xbinst --platform xilinx_vcu1525_dynamic_5_1 -d .
But I get the following error and I'm not sure how to resolve it:
****** xbinst v2018.2 (64-bit)
**** SW Build 2258646 on Thu Jun 14 20:02:38 MDT 2018
** Copyright 1986-2018 Xilinx, Inc. All Rights Reserved.
Attempting to get a license: ap_opencl
Feature available: ap_opencl
INFO: [XBINST 60-895] Target platform: /opt/Xilinx/SDx/2018.2/platforms/xilinx_vcu1525_dynamic_5_1/xilinx_vcu1525_dynamic_5_1.xpfm
INFO: [XBINST 60-267] Packaging for PCIe...
INFO: [XBINST 60-1032] Extracting DSA to /tmp/.Xil_sdaccel/xbinst-3476-ABCD-PCU/xilinx_vcu1525_dynamic_5_1
ERROR: Could not open '/opt/dsa/xilinx_vcu1525_dynamic_5_1/xbinst/firmware/10ee-6a90-4351-000000005aace1cf.dsabin' for writing.
ERROR: [XBINST 60-398] xclbincat failed
ERROR: [XBINST 17-53] User Exception: Dsabin generation failed.
ERROR: [XBINST 60-666] xbinst command failed.
What can cause such an issue?
The xbinst utility requires superuser privileges on the host machine to run. Please try to run "sudo xbinst ...".
