Executable file(xxx.exe xxx.xclbin) generated by sdaccel(runs on linux),I wonder if i can run the Executable file on windows10 or wsl(Windows Subsystem for Linux)?
Executable file(xxx.exe  xxx.xclbin) generated by sdaccel(runs on linux),I wonder if i can run the Executable file on windows10 or wsl(Windows Subsystem for Linux). I tried it on wsl ,but the messege showed "can't find opencl device" while it was running. wsl on windows can't access to PCI-express devices. I need help, thank you !
Hi, @wuzer57 ,
Currently NO windows OS or WSL are supoorted for board deployment.
Thank you for your reply!  I developed  Executable file on Linux, I just want to run it on windows , wsl or another linux operatin system without the whole sdx development environments. I developed it on Linux with sdx development environments and I must run it on linux with sdx development environment. now I feel helpless for that . Are there any solutions ?
Hi, @wuzer57 ,
Only deploying the borad doesn't need to install the whole sdx development environment.
You can refer to UG1301 for the detailed info.
