FPGA PCIe accelerator for a DEFLATE compression algorithm deployed on Windows application
I'm a total noobie here.  I'd like to make an FPGA PCIe accelerator for a DEFLATE algorithm running on a Windows 10 x64 application.  There are some nice looking code for doing such:
  • The Xilinx SDAccel example
  • and "High-Throughput Lossless Compression on Tightly Coupled CPU-FPGA Platforms"
These all use OpenCL/SDAccel.
My question is, while I know that Windows is not supported as an environment for SDAccel, is there a workaround?  Perhaps it is possible to export compiled SDAccel code into an FPGA IP core that can be re-imported into a tool (Vivado?) that can deploy to a Windows system?
回复: FPGA PCIe accelerator for a DEFLATE compression algorithm deployed on Windows application
Windows currently is not supported for SDAccel.
For DEFLATE realization, you may refer to https://github.com/xilinx/applications
For the kernel itself (HLS realization), you may integrate it into your existing platforms, but not into SDAccel +Windows.
brucey
