How to turn off OS version warning in 2018.3 SDx IDE?
Dear all,
I am using 2018.3 SDx and Ubuntu O/S 16.04.2.
In this environment, SDx IDE show OS version warning every build and run time.
I understand 2018.3 support from 16.04.4 but  I cannot change O/S version cause by some reasons.
Can I turn off that warning dialogue?
If you have any idea, it will be good for me.
Instructor
Instructor
@yilee
the set_msg_config & reset_msg_config commands will let you mask out messages.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_3/ug835-vivado-tcl-commands.pdf
Hope that helps
If so, please mark solution as accepted. (Kudos are also welcome :-)
Hi @xilinxacct
Your suggestion seems to handle Vivado's Messages.
But my case is different steps.
The error dialogue box comes from SDx IDE.
Exact messages are "Unsupported Operating System
XRT is supported on the following operating systems: Ubuntu 16.04.4 or higher,
Red Hat 7.4 or higher, CentOS 7.4 or higher.".
If you can solve this problem, let me know how to apply please.
