OpenCL SDAccel on Kintex-7 KC705 evaluation kit
I want to work on an image processing application on a Kintex-7 KC705 evaluation kit. For the same, I will be requiring the use of some OpenCL functions/kernels.
My question is whether Kintex-7 supports OpenCL based programming using Vivado HLS?
Hi, mandkepk15.extc@coep.ac.in ,
For OpenCL, HLS only support part of the flow.
If you intend to use SDAccel, you need to have an acceleration hardware platforms, such as U200, U250, VCU1525.
KC705 is not supported for SDAccel.
