Previously working SDx 18.02 fails to start on Ubuntu 18.04 LTS
When trying to start SDx, it fails with the following log file. The startup wizard dies when loading com.xilinx.sdx.reports. This problem began when I tried to open a report file from within the SDx environment. The SDx environment was working smoothly up till this point. I have tried rebooting to no avail. I would like to avoid reinstalling SDx if possible.
Hi, @rascalnik ,
SDx 2018.2 is not officially supported in Ubuntu 18.04 LTS.
You can refer to UG1238(v2018.2):
Linux Support
○ Red Hat Enterprise Workstation/Server 7.3-7.4 (64-bit)
○ CentOS 7.2
○ CentOS 7.3-7.4 (64-bit)
○ Ubuntu Linux 16.04.3 LTS (64-bit)
- Linux kernel 4.4.0 is supported
- Ubuntu LTS enablement (also called HWE or Hardware Enablement) is not supported
